Old 24th August 2002, 02:10 PM   (permalink)
quinjet is on a distinguished road
Default Any thoughts? replacing a potentiometer.
I am trying to replace a joystick pot with something that could be activated
using a reed switch. I am thinking along the lines of the switch open/closed
(number over time) = pot movement. So I suppose a counter (ic 555?)going to a digital pot but I am too inexperienced (dim) to work it out. Any
help, ideas link etc gratefully rece :? ived.
quinjet is offline   Reply With Quote
Old 9th September 2002, 10:36 AM   (permalink)
eiad2002 is on a distinguished road
How about using the MOSFET transistor :shock: as a switch? :roll: You would be able to accomplish what you need.....
Good Luck
Analyze
eiad2002 is offline   Reply With Quote
Old 9th September 2002, 06:54 PM   (permalink)
Super Moderator
mechie is a jewel in the roughmechie is a jewel in the rough
Default More info wanted
What is across the pot? is it a DC voltage, audio, etc.? Is it floating or refrenced to ground? Is it working as a potentiometer or just a variable resistor? Is it tiny current or lots of Watts?
Is the reed switch significant - voltage isolation or something?
What is the new control source - a pot to set the 555 frequency (full circle)?
How complex can the answer get before it's useless - could an opto coupler serve instead of the reed switch?
I need a memory upgrade ...
My head is full !
mechie is offline   Reply With Quote
Old 11th September 2002, 08:19 AM   (permalink)
8)
mechie,
The exact numbers you ask about I do not have to hand as I write but I can get them.
In essence I am trying to replace the forward reverse pot in a joystick 100k (5v) with a forward reverse motion of a wheel. This is why I thought of a reed switch and magnets and a circuit I saw using a 555 and 740 chips. Sadly it was not that simple, especially with my infants understanding of electronics. If this is still not clear just drop me a line.
Kevin.
Old 11th September 2002, 08:22 AM   (permalink)
eiad2002,
A MOSFET transistor? I will look this up and probably come back to you with a lot of ???????.
Ta,
Kev.
pins explain? motorized potentiometer..? Ctrl_Alt_Del General Electronics Chat 1 6th July 2005 11:05 AM
problem replacing switch with potentiometer jeramiez General Electronics Chat 4 13th January 2005 10:58 AM
Problems with Digital Potentiometer MrWho252 General Electronics Chat 12 23rd April 2004 03:42 AM
How do I generate a potentiometer output? klick General Electronics Chat 3 23rd November 2003 02:26 PM
What value potentiometer for headphone volume control? tom0826 Electronic Projects Design/Ideas/Reviews 4 31st August 2003 06:09 PM
