Old 18th March 2004, 07:28 PM   (permalink)
Default inverter circuit for computer light
I bought a cold cathode light kit for the inside of my computer and I wanted to make a circuit that would turn the light off when the Hard Drive LED on the front of my computer case turned on.
I tried making the following circuit, but it did not work. I don't know very much about electronics or making circuits, and I did go to my library and do research which though interesting, did not help me in making this circuit work.
The cathode light runs off of 12V that comes out of the computer power supply and I think that the Hard Drive LED runs off of 5 or 6 Volts (I'm not sure exactly because I can't find my notes right now)
I've tried using PNP and NPN transistors.
If anyone can help me, I'd really appreciate it.
Here is a link to my diagram
http://www.geocities.com/bwrogaa/index.html
jonjacob is offline
Old 18th March 2004, 08:08 PM   (permalink)
Default Hard Drive Light Voltage
The Voltage for the Hard Drive LED is 2V
jonjacob is offline
Old 18th March 2004, 10:18 PM   (permalink)
The circuit wont work as shown in your diagram. The CC light should be placed in series with the transistor. The transistor is acting as a switch.
Two roads diverged into a woods...i took the one less travelled by. R. Frost.
nettron1000 is offline
Old 18th March 2004, 10:28 PM   (permalink)
"Cold Cathode" lights operate at around 120volt,
you can switch the power supply on and off to the inverter with a transistor
or it can be perminantly powered up and the high voltage output to the tube switched with an optically isolated triac.
this is an ugly link and will look for a better schematic,
http://www.ee.washington.edu/circuit...CIISCHEMPC_002
tansis is offline
Old 18th March 2004, 10:50 PM   (permalink)
Cold Cathode" operates at around 120volt
Are you sure Tansis ? thought the voltage was alot higher than that, something like 300 V or so, depending on the length or something other.
Old 18th March 2004, 11:14 PM   (permalink)
I guess there are many factors involved and have yet to find any specific makers figures, but this is a good theory of operation link
http://www.infodotinc.com/content/ne...s/14178_85.htm
tansis is offline
Old 19th March 2004, 01:20 PM   (permalink)
So you want you lights to flicker on and off with your harddrive lights??
Use a comparator to fire a mosfet or something. I tried upgrading my HDD lights with a brighter one, but it wouldn't light thanks to insuficient voltage.
mmm...300v passes my test for a stun gun...
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
Old 19th March 2004, 06:18 PM   (permalink)
Actually, I don't want the cold cathode light to turn on when the Hard Drive LED turns on, I want the cold cathode light to turn off when the hard drive LED turns on. What I was thinking was that when the HD LED turns on it would switch the transistor on. Since the path through the transistor would offer less resistance than the path through the cold cathode light, the current would bypass the light. Then when the HD LED turned off, the transistor would turn off and the current would have to go through the cold cathode.
When I tried setting this up, the Cold Cathode light just stayed on no matter what the HD LED did.
As a side note, I did try putting the cold cathode light in series with the transistor just to see if I could get the transistor to do anything, and it did sortof work, but when the HD LED turned on and the transistor turned on the cold cathode light never did get as bright as it does when just plugged into the computer normally. And when the transistor turned off, the cold cathode was still on, even though it was much dimmer than it was when the transistor was on.
jonjacob is offline
Old 20th March 2004, 04:23 AM   (permalink)
yeah, like i said the comparator is the answer. If you want the CCFL off when the HDD light is up, just simply swap the comparator inputs.
pike is offline
Old 20th March 2004, 05:59 PM   (permalink)
What is a comparator? Is it a chip you buy at radio shack, or is it a circuit you have to make?
Also, I guess the circuit I described above isn't really an inverter, right?
jonjacob is offline
