Old 18th March 2004, 06:26 AM   (permalink)
ajay_kumar_d is on a distinguished road
Default 4 stepper motor control circuit- help!!!
Here is a schematic of the circuit designed by myself for controlling 4 stepper motors through the parallel port . though this circuit is simple , it does not seem to work !!!
could anybody PLEASE:
1 . check the drawing for fundamental errrors.
2 . transistor 2n3055 does not bias
3. input is 12 volts 5 amp regulated by 8 - 7812 ics
4. voltage across sl100 is 2.5 volts
also could anyone please clarify whether there will be any voltage drop across the 7812. i seem to get only 8 volts after rectification. the rectification circuit is made of 4 - IN4001 diodes in a bridge.
thanks in advance,
D.ajay kumar
m.tech (mechatronics engg.)
Vellore Institute of Technology
india 18/03/04[img]
[/img]
among the blind the one eyed man is the king
ajay_kumar_d is offline   Reply With Quote
Old 18th March 2004, 08:44 AM   (permalink)
Super Moderator
The drivers for the 2N3055's are shown as PNP, is this correct?.
If so they can't ever be switched on, to do so requires their base's pulling down to ground - there's no way to do that on your circuit.
Old 18th March 2004, 02:20 PM   (permalink)
Experienced Member
ChrisP is on a distinguished road
Send a message via ICQ to ChrisP Send a message via AIM to ChrisP Send a message via MSN to ChrisP Send a message via Yahoo to ChrisP
2N3055 is an NPN device...
ChrisP is offline   Reply With Quote
Old 19th March 2004, 11:54 AM   (permalink)
Experienced Member
pike is on a distinguished road
Are you planning to run the motors seperately, like on there own??
This wouldn't work, only one data bit (0 to 3) can be allowed to be turned on simultaniously (spelling?) . You can have as many bits turned on in data bits (4 to 7), but only one data bit between 0 to 3 can be on at once.
If 2 or more data bits (0 to 3) were on, 2 or more windings in each motor would fire. This isn't good.
hope this helps.
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline   Reply With Quote
