I'd like to build weather station, what could meaure only wind speed and then draw a graphic on a PC monitor. I'm thinking of useing micro motor and prop to generate voltage. Maybe someone has better ideas how to build it. :?:
| | #2 | |
Driving a motor also takes a fair bit of wind power, it's easier to spin a slotted disk and use opto-switches to detect the rotation. But either method can be (and has been) used. | ||
I agree, it seems that this is the way to go as far as wind speed, at least with commercial weather stations. I have seen some circuits which use open light bulbs (A bulb with the glass removed), but of course, this wouldn't be very smart for outdoor use. .FYI. this type of instrument is technically defined as an "Anemometer" which may help you with some searching for circuits. There are some circuits which use temperature and impedance for measurements as well. Check out this site: http://www.elecdesign.com/Articles/I...Articleid=3990 and this site for the relating circuit: http://www3.telus.net/chemelec/Proje...Anemometer.htm Hopefully this will give you some ideas. I don't know the specifics of the design, but I thought I could help with some links. Good luck! | |
| | #4 | |
| | #5 | |
Yeah it's a goofy one. I only knew how because I happened to have a piece of paper in front of me, which had Anemometer written on it. | ||
| | #6 |
As a side tidbit of information "Anemo" is latin for "Wind". I looked it up in the Word Root dictionary.
| | #7 |
being a kitesurfer and some one who is constantly watching the wind i have looked in to anemometer quite a bit. and by far the most intresting projects i have some across have involed using ultra sonic sensors. just talking to each other lie an x. the distanc eis constant but the speed is affected by the wind, this also gives direction and has no moving parts to grease etc. look here:http://www.unlv.edu/Research_Centers...niordesign.pdf or here for a kit: http://www.electronic-kits-and-proje.../3000/3168.pdf | |
| | #8 | |
Have you ever studied thermals? Very interesting topic, and quite the study! I studied a few years on thermals, because my dad flew gliders (Sailplanes etc.) in competition, and most of the lift is derived from thermals. That is, unless you're flying on a wind slope. Have you ever flown your kite using thermals for lift? I'm just wondering how it went etc. Again, sorry for the stray convo, but I can't help myself. | ||
| station, weather |
