can you provide me a simple but safest circuit using 4 white ultrabright led on to a 250vac(max) line. i just want to save some buck on high electricity bills! thanks in advance.
It's very simple but you better watch the high voltage.
Calculate R for current you want. For example for 25mA It would be R=250V/0.020A=12.5kOhm (12k will be fine). The power rating for resistor would be P=U*U/R: P=250*250/12000=5.2Watt so take a 10Watt resistor. This will still generate plenty of heat which is not desirable. To avoid this, you could use high voltage not-polarized capacitor instead of resistor (check the voltage rating so this thing doesn't explode in your face!!! You should be able to find something like 0.22uF 630VDC bipolar caps in old TV sets). Don't forget, if you opt for capacitor, you still need to put bleeder resistor in parallel with capacitor to avoid shocks if you ever take the "LED bulb" out of circuit (capacitor stores energy and bleeder resistor is to drain it down in few seconds). You can use for example 68k, 2Watt or 100k, 1watt to put in parallel with capacitor. Impedance of capacitor depends on frequency but it can be calculated by: Xc=1/(2*pi*f*C) If you use 0.22uF (microfarad) for 50Hz line frequency that should be: Xc=1/(2*3.14*50*0.00000022)=1/0.000069=14.5kOhm With bleeder resistor in parallel, branch impedance will drop even further (but not much) to some 12-13kOhm. That should give you ca 20mA current for the LEDs. |
