here i attached the diagram i have build. what i'm sure are. Occilator works OK Mosfets are OK ( i Have tested each one seperately ) but only one of them which drived by NPN transistor gets hot in a short time ( 1-2 minutes then after burns ) both are fully turns on and off. i've got to mention a thing is that as for testing i have connected 2 leds and lit them like a flipflop i have observed that the one fed via NPN transistor lights brighter then fed by PNP transistor. assuming PNP transistor causing more voltage drop then NPN ones. Since Mosfet drived by PNP transistor works grate i just think ( it might be wrong ) may be i should put grater resistor to the gate of the mosfet which fed via NPN transistor ( Burning one ). i'm not sure that this will be the solution. i'll give it a try. or i should use another occilator any suggestion please thanh you. | |
i got a question, why do you use the BD139 and 140 transistors? the 555 can drive the power tr mosfets by itself. and why did you use such power transistors(BD....)? | |
| | #3 | |
555 should be able to drive mosfets by itself. but it can triger N channel mosfet at positif edge of Square wave. so i should have also use P channel Mosfet for negative edge of the SW. and i have decided to use transistor. I've got use one or another. isn't it ok...??? | ||
I think the 555 supply is 15V(datasheet).In this case the PNP transistor always conduct. See this circuit.
the max suply for the 555 is 15V indeed. i got a suggestion, mesure the current of the circuit. | |
| | #6 |
I think Sebi has it there. You have a potential from the 555. Try a decoupling capacitor, maybe around five to ten MFDs John | |
| | #7 |
The capacitor distorted the signal rising an falling edge, in this case bad choice: if the FET-s become slowly rising signal, also burned. See my small modifyed circuit: here You can run the 555 from 5...15V, while the output sage working on 24V. In the original circuit was a problem with PNP stage: it can never closed, because 555 out in HI only 15V and in this case always remain 9V for open the PNP transistor.(it open 24V minus 0.7V!) | |
| | #8 |
Hi Sebi, yes, you are assuming he is running the 555 from 15v, which would mean that its output couldnt go over 15v. As T2 would need its base to go to 24v to shut it, you assume that it would always be open, and you may be correct. I think that the resistor chain R3,R1,R2,R4, thats 10K,20K,20K,10K, is wrongly valued. Consider the voltages, of the chain without T1 and T2 connected. That would be 4v,8v,8v,4v, across the resistors. I would expect that T1 and T2 would be well into current with that chain applied. This wouldn't actually matter if the drive to them was enough to fully close each in turn, which i dont think it would be from a 555. I would be inclined to alter that biasing setup until both T1 and T2 were closed, and include base stoppers like the output stage, with two capacitors from the 555. If the 555 is run from a lower supply rail, and i suspect that it is, then the drivers should also be run from that rail. If the 555 is being run at 24v it may be alright for a while, but you should not leave it like that. Here's a suggested alteration, i didn't really get what Sebi meant about the capacitors, i guess about five to ten MFDs, maybe a bit less. On the diagram, ive put min current, for here that should be only a bit away from conducting, i'm sure you know that. Best of luck with it. John. | |
| | #9 |
wow, John1 and the other guys, you realy are surprised me with your great efforts for sorting the problem out. i realy love this forum, i learn lots of thing. i have sorted out the heating problem ( i have built another oscillator with IC3524 ) the invertor is now working without problem. last night , i have tested the invertor by using continuously for 1 hour, without any problem at all. Now i have 220 volts 50 hz voltage generated from 24 volt battery. Now i am planning to change this inverter design into a UPS, can anybody teach me how to switch the line voltage to invertor voltage to supply the same load without any interruption. what i am planning is to use tristor or triyak at output of the transformer to switch the line to invertor or vice versa. But i presume there will be very short interruption. I don't know how to get this rid off. I guess a large capacitor should be connected to supply enough current for a very short time ( 2-4 milisecond ) but WHERE SHOULD IT BE CONNECTED Can anybody direct me on this regard too. | |
| | #10 |
Many UPS work with relay switch, and the charging via output transormer.In this case You need additional (precise) detector for exact switching. I recommend a continous charging for accu without any switching circuits. Yes, the 3524 is a best choice, developed for this application.It contains also dead-time control. | |
| | #11 |
Thank you Sarac for your appreciation, They dont usually switch the output from a UPS. The usual arrangement is to always run the 'special load' through the UPS, with the main supply keeping the batteries charged, in the event of a main supply failure, the UPS just carries on with no interruption. Purpose built commercial units are usually done like that. Switching the output from the UPS to restore supply to a 'special load' has other problems. That sort of thing is done but care has to be taken with the relay(s) or circuit breaker(s) to make sure that the supply cannot feed backwards down the line. I would suggest you don't switch the output, use it as Sebi says, under continuous load and charge. Regards, John | |
| | #12 |
Thanks John for "translating". Sometimes i just hope to understand my words,because i never learn english...
| | #13 |
You're welcome Sebi, You speak English better than i speak your language. Regards, John | |
| | #14 | |
You & Sebi are all talking abt ONLINE UPS. I'm aware of this, but my initial intention was build up an OFF LINE UPS bcs i thought that keeping the batteries on charge all the time, would effect it badly. for instance at max load ( 1 KW ) aprx.40A would be drawn from the batteries and i will have to use another transformer for keeping the batteries charged. this charging current will not be less then 40A or may be it should be double ( load current + charge current ) thus i should use 2 KW transformer for input voltage. I also thought that the electricity cost would be doubled bcs i will use 1kw but pay for 2 kw But on the other hand OFFLINE UPS's are using the batteries only when the blackout or brawnout Occurs and battery life would be longer. also i dont have to use second and bigger transformer then save money Just thinking above i have decided for OFFLINE UPS. i might be wrong. If you could, please tell me what is wrong and what is right for above written thoughts by considering that i am a learner. Regards to you all. | ||
| | #15 |
Hi Sarac, Yes, by having the UPS unit 'on-line' during use the feed to charge the batteries would have to be sufficient to run the load. The extra current to keep the batteries charged however, would not be much more, maybe not even noticeable. I agree that converting to low voltage, then back to 230 volts, is wasteful, but its not as bad as double. By having the UPS unit only nearby, not 'on-line' you would be using it as a standby supply, a supply that you could use if the mains were to fail. The usual method in this case is to mount a socket(s) on the UPS which is the output from the UPS. Then in the event of a main supply failure, the appliance can be unplugged from the main supply and plugged into the supply from the inverter, in this way it ceases to be an "Uninterruptable Power Supply" and becomes a standby supply. It is tempting to think a set of relay contacts could easily be arranged to switch the supply, and do this automatically, but the electrical supply companies are usually very strict about this sort of thing, and such a switching unit would usually require written permission from them before they allow its use, this would involve it being examined and passed as fit for use by their representatives. Such permission is rare for 230 volt systems. I do not know of a 'fail-safe' system that would satisfy the examiners, there may be one, but i dont know it. In my experience every suggestion will get a rebuttal. It is easy to think that a simple set of relay contacts would do this, but the examiners will say that contacts could stick, we may have people working along the line. You may suggest an arrangement where two relays are used, so the contacts are not shared, and 'sticking' would not transfer any supply backwards. An answer could be: what if this coil fails in use? The examiners are not easy to satisfy. The only system of transferring supply that i know of which is acceptable (at 230 volts) for a domestic user is where a different socket has the independant supply, and there is no possibility of 'cross-connection' Apart from the restrictions imposed by the electricity authorities there are also practical difficulties to be addressed when switching AC supplies, the problems of voltage and sychronising. The problem of voltage is not too difficult, but the problem of synchronising is quite difficult to get workable, although its not difficult to understand. The additional problem of making the voltage and the sychronisation automatic for the purposes of switching is not something that even an experienced electrical engineer would undertake to build from scratch without considerable thought. Another problem arises if the main supply resumes after a short interval, the synchronising and voltage would have to be matched before the standby supply could switch the load back to the main supply. It is not impossible, but it is not easy, and it is not a method that i have ever seen (for 230v) and it would require permission to use, which in my opinion would not be obtainable. (from the electricity authorities) However, if you use your own generator(s) or for some reason you are independant of the main electricity suppliers, then you can presumably do as you wish, you would still have to meet the statuary household safety regulations for domestic supplies, earthing, insulation, etc. Just give it a socket of its own. Thats the easy way. Or use it as a UPS, under load and charge. Let us know how you get on, and which way you choose to go, lots of us have battery run power supplies. Regards, John | |
