hey everyone was asking for some help to get ideas on how to start my design project,m was planning on ops: making a car headlight reminder, with both audible and visual warning systems, was wondering if anyone had any ideas or diagrams on this, not to use but to give me an idea on how to start.yours sincerely Omne | |
I think all successful circuit designs begin with a clear understanding of logic. Maybe it is just in your head - other times it helps to write down the possible things the circuit will have to contend with and the desired outputs. For you, it would seem that there are 4 combinations: input #1 input #2 output -------------------------------------- engine on + lights off = no signal engine on + lights on = no signal engine off + lights off = no signal engine off + lights on = signal (light and buzzer) So, you asked about where you should begin, this is where I start... BTW, what is a "simple/A level course?" | |
Hi Omne, I had an old motor with a battery that was not too clever. If i left the side lights on when i left the car, it would not start unless i was very quick to get back. After this had happened a few times, i decided that i had to fix up a buzzer or something to make sure i switched them off. My first arrangement was very simple and very, very effective. It comprised of a horn relay and a silicon rectifier between two parts of the car wiring. It made the hooter sound if i opened the car door with the lights on. I very quickly learned to switch off the lights before opening the car door. The hooter would stop of course when i closed the door, so if i wanted the side lights left on, that was ok. The interior light was operated by the door switch applying a chassis (body) connection to the interior light circuit to make it light. The external lights on the car all have one side connected to the chassis (body) of the car, and require a feed from the battery to be applied to make them light up. On cars here, the usual arrangement is that the side lights come on when the switch is actuated, and when the switch is actuated further the main lights come on in addition to the side lights. So the side lights stay on when the main lights are operated. The hooter is operated by a relay. The horn relay is operated from the steering wheel by applying a chassis (body) connection to the relay to make it operate. What i did was to connect a silicon rectifier diode and an old horn relay coil in series between the interior light and the external lights, mounted on the bulkhead under the bonnet. This did not interfere with the hooter. And it did not interfere with the interior light. It was effective, although i changed it later to work a buzzer which i salvaged from a different car. The diode is there to reject current from between the lights. The changes i made, i have drawn in blue. Almost a year later i changed it to work a buzzer instead. Best of luck with it, John | |
john, I have to say, that's a fantastic idea - I've often thought of doing a similar thing in my car, but have never thought of anything quite so simple - and often, simpler is better! 8)
Gee, I thought all cars made in the past 5-6 years already had a lights-on reminder installed at the factory. A ready-made device (with 2 connecting wires, buzzer, and instructions) is available at auto parts stores in the US for under $5 as an add-on for older cars. I still think it makes for good investigation as a science project. | |
| | #6 |
Thank you Phasor, The circuit started with much more in it. It took me a while to trim it down. Cheers, John | |
