Old 8th March 2004, 11:08 PM   #1
Default Flexible PCB
Hello there,
Is there any flexible PCB that i can mount (solder) a PIC16f84 or any other microcontroller and circuit components?
What is the material of that flexible PCB and how flexible is it?
Thanks a lot.
Marv.
\"you will become misfit, by being fit, to an unfit fitness\"
marvelous is offline
Old 8th March 2004, 11:12 PM   #2
There's a comapny called minco that makes flexible PCB that you can solder components to. Its quite flexible- like a thick plastic bag.
Brent
bmcculla is offline
Old 8th March 2004, 11:27 PM   #3
Brent
Thanks for the reply my friend,
You say it is as much flexible as a thick plastic bag. Then, it is not broken or damaged by wrapping or playing?
By the way, what is the difference between multilayered or single layered PCBs indeed?
Thanks again,
Marv.
Old 9th March 2004, 02:01 AM   #4
The flexible circuit shouldn't be damaged by bending unless the bends are very sharp. Its a little stiffer than a plastic bag.
Single layer PCBs have only a single layer of copper traces. Multi layer PCBs have several copper layers stacked up and can be connected with vias between the layers. The more layers on a PCB the more complicated the circuit can be. 2 or 4 layers is fairly standard.
bmcculla is offline
Old 9th March 2004, 02:17 AM   #5
Thanks a lot for the help..you are such a philantrophic person.
I think i will contact the PCB company to buy some f-PCB.
Take care,
Marv.
Old 9th March 2004, 09:17 AM   #6
Default layers
A question:
I have a very small (narrow) place to mount my PCB and that's why i want it to be a flexible PCB so that i can bend it somehow to make it fit that place.
Now....if i increase the number of layers of the FPCB, can i make my circuit smaller and smaller?
Thanks again for the help,
Marv.
Old 9th March 2004, 09:28 AM   #7
Default Re: layers
Probably, obviously the limit is the size of the components, I don't know if you can get flexible PCB's as multi-layer?. But all multi-layer does is glue thin PCB's together - so a four layer board is simply two double layer boards glued together (with some kind of insulation in between) and through hole plating joining the layers.
The first Pace Digital satellite receivers (for Australia or South Africa, as I recall) had massive early failures - all at roughly the same time. The four layer boards hadn't been cleaned properly during manufacture, and traces of etchant were left between the two boards. This resulted in tracks been etched away during use, and they all failed within a few weeks of each other :lol:
Old 9th March 2004, 03:42 PM   #8
Default Re: layers
Hi again,
Well yes. The company says they also have multilayered flexible PCBs (even up to 16 layers..gosh! )
...i am sorry to hear about the satellite disaster..i will wash clean mine before use
Take care and i will keep in touch with you if you don't mind.
Thanks again,
Marv.
Old 11th March 2004, 05:18 AM   #9
It might sound pretty cool for small electronics, but for something with bulky capacitors and/or heatsinks your better off sticking with your normal PCB.
can't you laminate a piece of copper foil to a transparency (with heat) and then etch your own board yourself???
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
flexible, pcb
