Old 5th March 2004, 07:23 PM   (permalink)
Default Multipe 5V outputs?
Hi Im a newbie
I am interning at a company. Today they asked me to desgin a test box that will out put a few diffrent things. One of the things this box needs is 4 seperate varible 5vDC outputs. The box will run off AC so I thought I would just order an AC to DC convert to get things going, but once I have my DC voltage how do I go about spliting it up into 4 outputs. Also once I do have the 4 outputs can I just use a pots to vary the voltages. Any advice part links or schematic links would be appriciated
Dark Lotus
foodang is offline
Old 5th March 2004, 07:54 PM   (permalink)
Just a few questions: the four outputs have common negative? (GND)
And how many amperes You need?
LM317 is a positive adjustable regulator up to 1,5A, and the output voltage adjustable by a potmeter.
Sebi is offline
Old 5th March 2004, 08:04 PM   (permalink)
These variable 5V outputs?
Are they for power or a control (low power) signal
If it is a low-power signal use OPAMPS with variable resistors to set the gain - thus via the pots you can vary the 4 output voltages
Styx is offline
