Old 4th March 2004, 07:58 AM   (permalink)
Default transistor help
ey guys. .. just a simple question.. :shock: . how would you determine or recognize if it is the emitter and the collector in a transistor by using the multitester manually..
:lol: :lol:
ellsworth is offline
Old 4th March 2004, 08:21 AM   (permalink)
The emitter-base junction breaks down at a much lower voltage than the collector-base junction. Some multimeters apply 9V at the terminals at the high resistance range. They will read a lower resistance when you connect the terminals to the base & emitter vs. base & collector.
"Having to do with Motion Control"
motion is offline
Old 4th March 2004, 01:02 PM   (permalink)
If u set a multimeter to the resistance measurement setting, there is a voltage available on the terminals, oppsoite in polarity to the terminals. Clip the terminals to the emitter and collector in any way. Now when u earth the base by a metal object say a forcep or a screwdriver or by ur hand, the resitance between the emitter and collector terminals will drop significantly if the terminals are applying voltage to the emitter and collector in the proper sense i.e. for the npn transistor emitter is connected to negative i.e. the red terminal and collector to the positive or the black terminal. The reverse is the case for pnp transistor. If the terminals are not connected like this the resistance drop will be almost insignificant.
It works for many transistors.
aryajur is offline
