yeah hi, im new to the site so ill start off by saying hello. ive got a project going at the moment regarding a shcematic i found on the net of a 'stungun' my main problem is being able to locate the transformer ,the one in question is called the lt44 it has a centre tapped winding of 1k on primary and 20k on secondary i can not find were to order these suckers anywere also is it possible to increase the output by using a higher rated transformer say like 1kct-200k? or if i use 2 9volts in series or parrallel ?,or could i lengthen the bank of capacitors on the end to get a higher rated output thankyou for your time,Brandon :?
yeah you could lenthen the bank of capacitors but your gonna have to find higher rated parts to handle the increased voltage.
BTW: where did you find the 200:1 transformer, i can't find these in Sydney anywhere????
www.winpicprog.co.uk - Great PIC language tutorials. |
An LT44 is a very standard audio driver transformer, but is a very old part now - probably early 1970's, if not 1960's.
Maplin still list them in the UK, have a look at http://www.maplin.co.uk and order code HX82D. The diagram doesn't make much sense - the output is labelled 30KV/8A!. That's 240,000W of power 8) I suspect 8uA would be more likely. |
yeah ive had a hard time tracking down the lt44 1k-20k one of the only places ive found that sells them is tandy electronics and sadly enough there only available trough there telephone amplifier kit not as a seperate item im waiting on reply to other companies that might stock them seperatly,as the lt44 is rated at 1k-20k will it up the output if i change the transformer to 1k-200k??
The LT44 spec sheet states that it's IMPEDANCE is
. . . 1k0 Ohms (centre tapped) to 20k Ohms I can find no refrence to its WINDING RATIO The latter is the figure that will define your step - up ratio, the impedance will have more effect on output power than voltage. Has anybody tried a tiny mains transformer (240v to 3v or similar), wired backwards this should give some 240/3 = 80v out for the multiplier to work with; A four stage multiplier could then give 1kV ? ----------------- I find it amazing how popular these "stun gun" circuits are and yet no-one ever seems to report their results in anything other than anecdotal form. Has ANYONE actually measured their circuit's output.
I need a memory upgrade ... My head is full ! |
wouldn't that only give you 180V - surely you wouldn't even feel that...? |
(permalink) | ||
But that's not the final voltage, the 360V AC is fed through a Walton-Cockcroft multiplier, which builds the voltage up - the amount depending on the number of stages, and producing a DC voltage at the output. |
