+ Reply to Thread
Results 1 to 7 of 7
Thread: automatic braking system for cars
  1. #1
    kumbanadan Newbie
    Join Date
    Feb 2004
    Location
    earth
    Posts
    4
    Default automatic braking system for cars
    [list]i am doing a project on automatic braking
    system in cars. my idea is to put a sensor in
    the front of the car and connect to the brake system.for example if a car is in front of u and u didn't see that.befor u hit the car the sensor will detect and automatically brake.
  2. #2
    mozikluv Newbie
    Join Date
    Aug 2003
    Location
    Philippines
    Posts
    372
    Default sensor
    what you need is an ultrasonic proximity sensor, but this has a limitation as to effecive distance. i have that circuit installed on my wife's car. it help her when she parks her car. women are sometimes not good in judging distance :wink:
    \"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~
  3. #3
    kumbanadan Newbie
    Join Date
    Feb 2004
    Location
    earth
    Posts
    4
    Default ten
    01191
  4. #4
    canadianpoet2012 Newbie
    Join Date
    Feb 2004
    Location
    UK
    Posts
    76
    Another more reliable but by no means easy way of doing it is to use lasers. This would increase the range, but you'd have to be careful about directions, focusing etc.
    Basically what you need to do is, reliably, transmit some form of signal out the front of your car on the bumper (ultra sonic, sonar, light, whatever) and then time how long it takes to receive the signal again. Poor mans radar basically! You'd have to do some very impressive tests and calibrations however and have alot of complex brains in your circuits!
    You would need to take into account your speed, the weather conditions, road surface. You'd also have to find a way of smoothly applying the brakes! Not an easy project!!! But it is possible. The US military tried employing similar techniques back in the early 90's to make automated vehicles for the battle field. And Mercedes uses automatic cruise control on their more hi end models. You could try contacting Mrecedes HQ technical department or have a snout about on the web, see if you can find out more about it, may help.
  5. #5
    crust Okay
    Join Date
    Sep 2003
    Posts
    728
    Default Re: sensor
    Quote Originally Posted by mozikluv
    Where did you get that / what car is that on? That would help her quite a bit.
  6. #6
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Default Re: sensor
    Quote Originally Posted by crust
    You can buy them as addons at any car accessory shop, it's a very common item, some manufacturers even fit them as standard.
  7. #7
    mozikluv Newbie
    Join Date
    Aug 2003
    Location
    Philippines
    Posts
    372
    Default ultrasonic
    hi crust,
    the car my wife is using is a korean KIA-Pride and its a small car like a Mini-Cooper. i had installed the unit at the rear coz that's where she has the weakness. the rear bumper has already dents and scratches ops: i had the thing set at 3 feet range.
+ Reply to Thread
Tags for this Thread
