hi
i have some problem about making a electronic switch. im currently doing a project base on a 68HC11 micro-controller board. im trying to have the board to control another board by using the output pins of the board as a switch. when the pin is high its 3.3v and low is 0.9v. and when the pin is high, i want it to be connect and low to disconnect. i have a switch using a 2n222 npn transitor but it seem to activate even when the pin is low. is there any other of making a electronic switch ?? i have draw the circuit of the switch i have do but dun seem to work .. |
add more resisters in the trigger wire to keep the transistor from leaking
OK, first let me say that I do not have the specs for a 2n222 so my answer is more in general. You do not show what supply voltage the transistor gets but it should have a load resistor, either in the collector or the emitter lead.
Next, try to use a lower value than the 1k5 resistor at the base (or a higher resistance than the 4k7 resistor). Measure the base to emitter voltage with a digital volt meter, it should be less then 0.5V for the transistor to turn off. |
is there any possible way to use a relay ???? |
(permalink) | ||
And yes it is possible to use a relay - whether or not you need to do that depends on your load requirements. If you do use a relay, you will use more parts and they will likely be larger in physical size. |
i have draw the actual connection of my board....
can help me see what have i done wrong in the connection.... |
The 2N222 emitter should return to ground, not -9 volts. If the IC requires a negative voltage to be off, then use a 2N2907 PNP transistor with the emitter returned to +5 volts.
see my website: www.geocities.com/russlk |
i have some qns on the relay thing... if i have a relay that work on 5v but i only have 3v which is not enough to activate it. can i add in another voltage source which is 2v to add it up to 5v ?? and if i remove the 2v supply will the relay be d/c ?? |
If you add the 2 volts in parallel as I suppose you are trying to do, u will be effectively loading the 3 volt supply and may damage it too. The 2 volts should appear in series witht the 3 volt supply.
With a transistor switch You can choose the relay voltage independently from proc voltage.
can i do it by connecting out source to the base of the transistor and other to the collecter of the transistor ?? |
