Here is the link. I'm a begginer and I'd like to know how to follow this diagram with these parts. It would be really helpful if someone could help me here. Thank you very much for your time.
http://www.aaroncake.net/circuits/inverter.htm |
I just put this together for you:
It will look something like this, but i think I got the wrong transformer (T1) chip, its kinda small and I dunno how small or big these things really are, so... |
Even the diodes package is wrong.
"There is no way to peace, peace is the way!" |
yes, you put transistors instead of the diodes, i might work.
and another thing, look at how thin the lines are, they will sart heating at below 1A and 1-2A will be enough to destroy them |
I was talking about the SMD diode package which he has used instead of normal DO type package.
And one more thing, normally inverter transformers are not mounted on the PCB due to their large size. So just put large pads for its connections on the PCB.
yes, i didnt look carefully. but the 2 transistors are not connected well.
and the circuit lines are too thin. |
Whoa! Thanks a lot for that diagram but I don't know how to make a PCB board. I was just gonna use a regular board(the board with the copper circles and a lot of holes) from radioshack. I'm just a begginer and still don't understand this diagram:
http://www.aaroncake.net/circuits/inverter.htm Please let me know about this. Thank you very, very, much for your time. |
do you know you dont understand how it works?
and another thing. this inverter is capable of absorbing 15A(!!!!!) from the power suply, so you need to make really good conections if you are going to use it at full capacity. the circuit is relatively simple and you can do it without a board, because you will need also great heatsinks for the transistors so you might not place them on the board... |
I would suggest that when you build this circuit you call a friend who is good in electronics to check it out...
yes, it is a good idea, beacuse the output of the circuit can be dangerous...and shocking.
and makes you tickle
Well, if that is what you call tickling then I don't like it at all :lol: :wink:
you know...i find electricity quite....SHOCKING....!!!!
I Built it and used a 1/100 ratio transformer and knocked myself across the room and almost died.... Im done with electronic's.... (Probably Not But i quit for now)
I once experienced a good 4kV shock which threw me off the wooden table I was sitting
