Hello everybody.What I am trying to accomplish is use 6 switches that have a different resistor for each switch,and of coarse give a different voltage with each down a single wire.This part of the project is fixed and I cant change it.Also, the switches do not switch a positive,they switch a negative.This is all on a 12v system.What I want to do is get a seperate output by using a lm3914 a/d-led driver chip.The problem is the negative switching from the switches,as the lm3914 requires a positive.How can I go about converting the different negatives to a positive.When my meter is connected to the switches,positive to 12v,and the negative lead on my single wire,the voltage will change anywhere from 8v to 11.5v depending on which switch is pressed.Please help.Thank you for the time... :?
Can you draw a diagram or at least clarify what switching a negative means?
Connect the LM3914 between ground and -12 volts, ground being positive, then the switch signals will be positive relative to the LM3914 negative termenal.
see my website: www.geocities.com/russlk |
Len |
I am sorry for the confusion,as I was tired when I wrote the post,and I was a little confused myself..
P.S.-If it helps I have the resistance of each switches resistor... |
It is impossible to comment without seeing the circuit. The description is not adequate.
Len |
