Old 11th February 2004, 03:21 PM   (permalink)
Default Infrared burglary fence
I am writing a post graduate project on the topic, 'Infrared Burglary Fence
with Intrusion Location'. I need assistance/contributions on how to go about it. The transmitter should be active infrared. The system must be able to detect the location where the intruder came in.
I also need circuit diagrams.
Thank you.
Purdue U.
purdue umaru is offline   Reply With Quote
Old 11th February 2004, 03:45 PM   (permalink)
In what form do you need loaction? ie. in x,y co-ordinates or just the direction? Instead of IR beam use LASER for better directivity and less complexity.
Old 11th February 2004, 04:02 PM   (permalink)
The location is directional and i prefer IR
Old 11th February 2004, 04:45 PM   (permalink)
What is the permieter of your compound and what type of IR source are you going to use? is it IR LED?
Old 11th February 2004, 07:39 PM   (permalink)
Hi purdue umaru,
If you put Infra Red beams each covering sections,
then an interruption could alert you to a section,
the more sections wanted, the more beams.
Depends how precise you need to locate ...
Best of luck with it, John
john1 is offline   Reply With Quote
Old 12th February 2004, 09:55 AM   (permalink)
The area I want the system to cover is 400 sq Meters for a start and intend using IR LED as the IR source.
Regards,
Purdue.
Old 12th February 2004, 10:00 AM   (permalink)
The problem is that i want to use only one receiver.
regards,
Purdue.
Old 12th February 2004, 12:43 PM   (permalink)
I don't think it is possible to detect 4 directions with one sensor. What is the problem in using 4 sensors? You mentioned your distance is 400 meters. So which LED are you going to use which can focus its radiation upto 400m. Even if you use bunch of LEDs I don't think it will be sensed by any photodiode without high gain amplifier. IR LASER will be a better alternative. You can easily use it upto 1km.
Lets see if any expert comes up with a idea. :idea:
