Hi, basically I want to build a very very simple bass amp on a protoboard for a project with the speaker included that is portable (so powered off small batteries). I was thinking of using a design similar to the below, but I don’t know what values of resistors and other components to use, also if I did use 12 V power supply I wouldn’t want the op amps to saturate so I going to have 2 limit my gain quiet considerably. And how would I get the – 12 V off one battery? Would I need 2?
Has anyone got any ideas on what values I should use or a better circuit design as I don’t know how this will sound. Also does anyone know the typical output from a bass guitar? I imagine it something less than 1 mV but am unsure. Thanks for any1 who replies, cheers. markdude |
(permalink) | ||
The first thing you ned to decide is how much power you want, and what sort of battery supply you are intending using. For a first suggestion - use a 4 ohm speaker, not 8 ohm - this will provide double the power off the same voltage supply. Using a 12V supply (like a car battery) you can get 4 watts RMS in to 4 ohms, using a bridged amplifier you can get 16 watts RMS in to the same 4 ohm speaker. Using circuits designed for car radios is probably a good way for you to go. Quote:
Thanks!
I will look into a bridged amplifier and find out about them first, I could use a car battery I guess but I was thinking something smaller and more practical to transport. But I prob need a hefty battery anyway to be able to power the op amps and the speaker adequately without it running flat quickly anyway. I will look into the speaker being 4 ohms as well and reply with what I find out. Sorry about the 1 mV it was a mistake I meant 100 mV, so I think it less than 100mV output from bass, but I don't really know for sure. Thanks for the help cheers. Markdude |
I looked into the bridged amplifier but I didnt really find much else out other than it can quadrouple the wattage into a speaker, how would I wire it up so that I could keep the design similar to the one I already have (above).....
thanks for any possible help. Markdude |
There are lots of chips which are designed as bridged amplifiers for 12V car use. Have a look at the datasheet for the (single ended) TDA2006 at http://www.videosistemas-net.com/dat...s/TDA-2006.pdf which gives an example of how to bridge it (although on +-12V).
Thanks again! I looked at using the bridged amplifier circuit on them datasheets and I think I would be able to use it and for the power gain out of the speaker I would have thought it was certainly worth it.
I still have the problem however of having a - and a + 12 V, is there any possible way of achieving both off 1 battery, it could be a standard car battery or other 12 V source? Thanks for any help. Markdude |
The TDA2006 datasheet I mentioned was just to show you what bridging is, there are LOT'S of single IC bridge amplifiers that work off a single 12V supply - intended for car radio use - your car radio probably has at least two of them inside. The TDA2005 is a single bridged 12V amplifier, you could try searching for that one. |
