Hello, can any1 help me with my random heads and tails generator? has any1 got any designs?
Attached is a Psudo-random number generator All those D-types can be replaced with a ripple counter (just used descrete to show how it works). Also by changing the point at which the XOR gate is attached different random sequence is generated. It is not really random, run it for long enough an a pattern will emerge. Increase the time between start of the "random" sequence by increasing chain of D-types. By tagging a LED to the final output you should get a randon light ON or OFF to represent HEADS or TAILS. By tying in a switch and maybe another D-type you can have it latch for each switch press, this introducing an outside random effect (from humans) thus making it completely random. |
alternatively, u could use something like the circuit below, which uses a 555 as a Astable, and a 4017 decade counter, which resets on the third output, so that the first two ouputs flash on and off in sequence whenever the push switch is pressed. The values of the components are such that it would flash sooooo fast that you would not be able to let go of the switch on one particular output (head or tails) so it is effectivly random.
Tim |
possibly a temperature transducer or pressure transducer into an A/D and take the least significant bit? im no electronics guy, though.
-ffuzz |
The circuits submitted by Styx and grrr_arrghh are unnecessarily complex.
You could simply connect the LEDs to the output of the 555. When it is stopped, one or the other will be lit. In case the mark/space ratio of the 555 is not exactly 50/50, then a J,K Flip Flop could be used to divide the output of the 555 by 2 thus providing the 50/50 signal. Len |
I posted about one of these a while ago and got some pretty good sources. This is my post: http://www.electro-tech-online.com/v...516&highlight= :wink:
When life gives you lemons... make a battery. |
Here are another 2 options
Len |
