Old 5th February 2004, 04:47 AM   (permalink)
Experienced Member
mozikluv is on a distinguished road
Default 555 & 4017
hi guys,
Question 1. how do you connect 2 units of 555 to the clock pin of the 4017
(if possible)
Question 2. timer A operating at astable mode inputs first to the 4017, during the off state of timer A, timer B operating at mono inputs to the 4017 at the duration of the off state of timer A, is this set up possible?
\"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~
mozikluv is offline   Reply With Quote
Old 5th February 2004, 06:42 PM   (permalink)
Experienced Member
laroche73 is on a distinguished road
Default dual-clock on 4017
Your question is a little confusing, Mozikluv. What are you trying to accomplish? Is the second 555 timer (B/mono) triggered off the first timer (A/astable), or does it have an independent trigger source?
The 4017 has two possible sources for an input clock, the Clock input and the Clock Enable input. Either one (or both) can be used as clock inputs, but they have opposite trigger polarities. A rising edge on the Clock input will increment the 4017 while the Clock Enable pin is held low, and a falling edge on the Clock Enable increments the counter while the Clock input is held high. One other difference between the two inputs, my datasheets show the Clock pin having a schmitt-trigger input, and the Clock Enable being a normal CMOS input (this may depend on the manufacturer). Hope this helps.
laroche73 is offline   Reply With Quote
Old 7th February 2004, 12:32 AM   (permalink)
Experienced Member
Default 555 & 4017
hi laroche 73,
sorry if my post had confused you, the timer B operating in mono shall be triggered by timer A which is operating in astable mode. all timing resistors will be pots so can easily make adjustments.
when i said how do i connect both timer output to the clock input of the 4017, i meant, do i connect it directly or do i have to put a component like a signal diode in between the timer output and the 4017 clock input.
Old 7th February 2004, 05:02 AM   (permalink)
Experienced Member
Default driving one clock pin from two outputs
Hi mozikluv, no problem . The LM555 has a totem-pole output stage, so you do need to OR the outputs together with diodes, transistors or a logic gate in order to drive a single input. Parts like the LM311, which have open collector output stages, can have their outputs wire-ORed together (but require a pullup) since they can only sink current.
As noted above, the 4017 already has a built-in OR gate with "Clock" and "Clock_En" being the inputs (though the "Clock_En" polarity is inverted). As long as you account for the inverted "Clock_En" polarity, you could attach the output of timer "A" to the "Clock" input, and timer "B" to the "Clock_En" input. In other words, you could make use of the 4017's built-in OR clock structure instead of constructing an external one (This may not save on parts though, since you'd probably have to invert one of the timer outputs to make it work).
Old 9th February 2004, 12:23 AM   (permalink)
Experienced Member
Default 555 & 4017
hi laroche 73,
thanx, now i can proceed playing around with the 4017.
Old 9th February 2007, 07:03 AM   (permalink)
Fred1 is on a distinguished road
Hello;
I'll start off with the parts I am using. A 555 timer and a 4017. I am trying to set up a string of chase lights . The circuit works but not the way I want. I need the lights to start running then to slow down to a stop. Can anyone help me with a circuit for the 555. I checked out the mondstable and astable crcuits but that did not help.
Fred.
Fred1 is offline   Reply With Quote
Old 9th February 2007, 12:15 PM   (permalink)
Experienced Member
House0Fwax is on a distinguished road
Fred1, you should really have started a new thread for your question.
However.
Check out this link ---> http://www.quasarelectronics.com/3003.htm
And look at the " View Product Documentation " PDF. link, it explains everything you want to know.
House0Fwax is offline   Reply With Quote
Old 10th February 2007, 02:25 AM   (permalink)
mariobar11 is on a distinguished road
gudday, i need help who have a diagram of any power amplifier that have a power supply of 60v(+,-) 50amp, w/common ground.The reason i have to rebuild w/ this existing power supply i have.thanks..
mariobar11 is offline   Reply With Quote
Old 10th February 2007, 03:42 AM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
A power supply with 60V(+,-) 50Amp is 6000W isn't it?
Old 10th February 2007, 06:57 AM   (permalink)
Super Moderator
Yes, and in the UK you can only get about 3000W from a single mains plug, and it's less in 110V countries.
Old 11th February 2007, 12:13 AM   (permalink)
Tnx AUDIOGURU AND SIR NIGEL GOODWIN.
My plan rebuilding an amplifier just a mere 200watts solidstate audio amplifier that i have to recycle the existing transistors and capacitors.i have no intention to maximize the capacity of the power of the transformer and our existing power supply is 220vac.
hope you can help me with this my input power of my transformer is 220vac and the output 60vac(2) & a center tap.
THANK YOU VERY VERY MUCH FOR A SUCH HELP AND VERY MUCH PLEASED WITH THIS SITE AND PEOPLE LIKE YOU OUT THERE WILLING TO HELP. MY GOD BLESS YOU OUT THERE AND MORE POWER TO THIS SITE "ELECTRO TECH"
Old 11th February 2007, 09:55 AM   (permalink)
Super Moderator
You might have a look at http://www.ampslab.com/projects.htm
Old 11th February 2007, 10:24 AM   (permalink)
Experienced Member
Yes, you need a cooker outlet or three phase to get that much power.
Hero999 is online now   Reply With Quote
Old 12th May 2008, 09:46 AM   (permalink)
fahad_mahmood is on a distinguished road
hello everyone,
i have got a problem,i am using 5 4017 counters in order to flash 35 leds.but the problem is that i want these leds to be flash extremely fast but thats not happening.i am using astable configuration of 555 timer and i also made some changes in resistors and capacitor configuration of the 555 timer.but not get the result which i wanted.plz can anybody help out on this.or give the reason why its not happening.
Fahad
fahad_mahmood is offline   Reply With Quote
Old 16th June 2008, 05:08 AM   (permalink)
Johnny Hu is on a distinguished road
If I understood what you want, check this for the 4017 circuitry: http://www.doctronics.co.uk/pdf_files/4017.pdf (fig7 - there are in fact 9 avaiable outputs for each 4017 in this topology, not 8 as mentioned in the pdf, so with just 4 4017 you be able to control until 36 LEDs. If you really want to control 35 LEDs, connect Q8 instead of Q9 in the last 4017)
As for the AND gates, you could use the 4081.
And for your astable 555, remember that f = 1/(.693 x C x (R1 + 2 x R2))
Here is a good tutorial about the 555: 555 Timer/Oscillator Tutorial
Enjoy it!
Johnny Hu is offline   Reply With Quote
