+ Reply to Thread
Results 1 to 10 of 10
Thread: Help with sum logic gates n..........
  1. #1
    umer007 Newbie
    Join Date
    Dec 2003
    Posts
    51
    Default Help with sum logic gates n..........
    Can sumone plz gimme an electrical analogy for NAND gate, NOR gate and a XOR (EOR) gate plz. By electrical analogy i mean a ciruit diagram that describes how the gate works.
    I am tryint to attach an example of a AND gate i made on Paint but it said bmp not allowed or sumthin. Plz tell me how to post so i can show u a example or if u know wt im talkin abt plz answer post.
    TYVM
  2. #2
    Russlk Newbie
    Join Date
    Nov 2003
    Location
    New Hampsire, USA
    Posts
    2,457
    jpg format is acceptable, you need a scanner or bmp converter.
    This is my anolagy for the gates:
  3. #3
    umer007 Newbie
    Join Date
    Dec 2003
    Posts
    51
    plz. tell me wt A. B and C stand for
  4. #4
    Styx Good Styx Good
    Join Date
    Dec 2003
    Location
    UK
    Posts
    1,724
    A and B are the input to the descrete logic
    C is the output
    Also altough you asked fo r NAND,NOR,XOR the simplest gate AND and OR can be made from two diodes and a resistor - although can only have a fanout of 1
  5. #5
    umer007 Newbie
    Join Date
    Dec 2003
    Posts
    51
    I wz wonderin if u cud gimme a analogy in the form of a circuit that is attached.
  6. #6
    ljcox Good ljcox Good
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Quote Originally Posted by umer007
    The circuit you attached is an AND gate using switches. If you label the switches A and B, then the lamp glows when A AND B are closed.
    If you put the switches in parallel, you have an OR gate. The lamp glows when A OR B (or both) is closed.
    To create an analogue of a NAND gate using switch contacts, connect 2 normally closed switches in parallal. Thus the lamp does NOT glow when both switches are operated.
    To draw circuits for this forum, I draw them in PowerPoint and then save them as a .gif file. This file can be attached to a post.
    Len
  7. #7
    umer007 Newbie
    Join Date
    Dec 2003
    Posts
    51
    Yes i know but i need NAND, NOR, EXOR in that kind of drawing. Plz post if u know.
  8. #8
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    I think you posted this while I was editing my previous post to describe a NAND analogue.
    A NOR analogue would be 2 NC contacts in series. So the lamp does NOT glow if A OR B is operated.
    I'll draw a XOR and post is shortly.
    Len
  9. #9
    umer007 Newbie
    Join Date
    Dec 2003
    Posts
    51
    wud u mind drawin NAND, NOR and EXOR for me plz. It wud help me understand them alot.
    TY
  10. #10
    Join Date
    Dec 2003
    Location
    Melbourne Australia
    Posts
    2,446
    Here are a NAND, NOR and XOR gate. I'll leave you to draw the lamp and battery.
    NAND - lamp does NOT glow if A AND B are operated
    NOR - lamp does NOT glow if A OR B are operated
    In the XOR case, the lamp glows when A is operated or when B is operated but NOT if both are operated.
    This is how lights in houses can be controlled by 2 switches.
    Len
+ Reply to Thread
Tags for this Thread
