Thanks for the circuit, works well, would you be able to tell me how many turns is needed for a 1/2 inch form......
also to increase the distance between the coils what can be done..... cheers, thanks heaps again for your help!! |
For 1/2 inch diameter coils, transmit 11.8 turns #30, receive 10.7 turns #30. One way to be able to increase the spacing between coils, is to run the oscillator on higher voltage (more power).
see my website: www.geocities.com/russlk |
I've noticed that the 100 ohm resistor connected to the emitter of the tranny is getting quite warm - is this to be expected?
i'm running the circuit on a 12V DC 300mA plug pack...... the resistor is a 0.5w metal film type..... cheers |
Power in the 100 ohm resistor is probably around 300 mW so it should be warm, but not painfully hot.
it's getting warm enough that i can't hold on to it
would changing it to a 1w help?? cheers |
Well---- I think the circuit must be operating inefficiently. Let me simulate the circuit and get back to you.
The power in the 100 ohm resistor is about 800 mW, so yes use a 1 watt resistor. Also increase the 10K to 1 megohm for better efficiency.
thankyou for your help, i will give those things a try...
cheers |
