Old 29th January 2004, 06:12 PM   (permalink)
Default Please Help: Impedance Meter
I am suppose to build Impedance Meter for my Senior Design with the following specifications:
1. Freq 20KHz to 500KHz
2. 1ohms to 1000ohms
3.-180deg-180deg
I have read a lot of confusing literature about this. Does any body have an idea on how to implement both the magnitude and phase measurement circuit on the same circuit.
Oluvision is offline
Old 29th January 2004, 07:22 PM   (permalink)
I dont think it is too difficult to do both amplitude and phase in the same measurements. Is it supposed to be all analog (i.e. outputs a voltage/current that represents the phase/impedance) or do you have some type of analog-to-digital conversion and then use a micro to handle the rest of the system?
Since you are setting the frequency yourself, if you are supposed to do the work in the digital domain, you can do a very simplistic DFT that would just need 1 multiplication per sample. You would then have both the amplitude and phase of the output signal. If you also capture the input signal, then the change in phase/amplitude is easily measured.
In the analog domain, you would build a phase detector circuit that would give you a voltage that is linear with respect to the phase difference between the input/output signal. The RMS amplitude difference in conjunction with the known source impedance could then be output.
crust is offline
Old 29th January 2004, 07:53 PM   (permalink)
Default For: Crust Re: Impedance Meter
Thanks for your assistance Expert Crust
Crust:
"Since you are setting the frequency yourself, if you are supposed to do the work in the digital domain, you can do a very simplistic DFT that would just need 1 multiplication per sample. You would then have both the amplitude and phase of the output signal. If you also capture the input signal, then the change in phase/amplitude is easily measured. "
Can you please explain more about DFT(above paragraph) and the digital procedure in general. Also a circuit diagram (if available) will be apprecitated).
Old 29th January 2004, 08:20 PM   (permalink)
do a search on DFT (discreet fourier transform) on google. You'll find several good descriptions on how to do it.
A rectangular bear is just a polar bear after a coordinate transform. -- I dunno who.
A recent study shows that research causes cancer in rats. -- I dunno who said that one either.
Noggin is offline
Old 30th January 2004, 05:08 AM   (permalink)
To measure the phase, use a small resistor in series. It should be small compared to 1 ohm. Comparing the voltage across the current sense resistor with the voltage across the DUT (device under test) in a X-OR gate will give the phase angle. plus or minus 90 degrees is doable, but I don't know about 180 degrees.
Russlk is offline
