| IS IT USEFUL TO ANY ONE? | |
| The 22uF in feedback loop not a good idea: the circuit respond very slowly for output changing. | |
| Another problem is non linear output. About half of turn on the potentiometer will make only ca. 1/2Volt change on the output (from 1.2 to 1.7). Make sure that potentiometer end connected to 100 Oh resistor is shorted to wiper. | |
| I don't see why you need 1/2Watt (500mW) rating for 100Ohm resistor. It will never see even 15mW but sure it doesn't hurt to oversize. | |
| The miliamp meter should have shunt. | |
Feedback is not dependent on having impedance from adj to GND. Consider that you can ground the adj pin and make a 1.25v regulator. Feedback occurs because the circuit attempts to maintain 1.25v between the output and adj., independent of the impedance between adj and GND. If you use this cap, National recommends a 1N4002 (any of the 1N400x series should work) from output to adj, cathode to output. The unlabeled capacitor from input to adj in the schematic above should NOT be used. | ||
| missing Velue of capacitor is 10kpf please revew the circuit | |
| Right, Ron: i've also found it in my catalog, but - as You wroted - also need a diode. But all application show the potmeter between adj. and GND pins, not as voltage divider... | |
With the others suggestions implemented, this supply will work. It has the following disadvantages: 1) It is linear so it suffers from very poor power conversion efficiency. 2) Power output will be limited by the LM317 - put it on a heat sink and you can get more bang for your buck. 3) other than bulk smoothing caps, no efforts are made to reduce noise conducted from the line - but you might not care about that noise | ||
| Only that LM317 wod be a litle usefull to me.
