| New Member | Hi Guys, I would like to build an IR controlled switch. Is there any simple circuits for building the receiver and emitter? Can I install a cascade of IR's so that the signal can be picked up 360 degrees? I would like to control a 7 amp device. I do know I will have to use relays. Many thanks, Striker. |
| Experienced Member | What are you planning to use as a source? What is the distance between the emitter and receiver? Is the source going to rotate? What, exactly, are you trying to do?
__________________ see my website: www.geocities.com/russlk |
| Super Moderator | Quote:
You could then use the PIC pin to feed a driver to switch your relay, although a relay isn't the only choice. IR receiver IC's are essentially open-collector, but with an in-built high value pull-up resistor - you should be able to simply connect them in parallel. | |
