Old 20th January 2004, 08:38 PM   (permalink)
Striker is on a distinguished road
Default IR Switch
Hi Guys,
I would like to build an IR controlled switch. Is there any simple circuits for building the receiver and emitter? Can I install a cascade of IR's so that the signal can be picked up 360 degrees? I would like to control a 7 amp device. I do know I will have to use relays.
Many thanks,
Striker.
Striker is offline   Reply With Quote
Old 21st January 2004, 12:43 AM   (permalink)
Experienced Member
Russlk is on a distinguished road
What are you planning to use as a source? What is the distance between the emitter and receiver? Is the source going to rotate? What, exactly, are you trying to do?
Russlk is offline   Reply With Quote
Old 21st January 2004, 06:05 AM   (permalink)
Super Moderator
Default Re: IR Switch
Originally Posted by Striker
Hi Guys,
One of my PIC tutorials at http://www.winpicprog.co.uk shows how to switch PIC pins on and off using IR, it uses the Sony SIRC system, so you could use a Sony remote to operate it - or build a transmitter as well, details are given.
You could then use the PIC pin to feed a driver to switch your relay, although a relay isn't the only choice.
IR receiver IC's are essentially open-collector, but with an in-built high value pull-up resistor - you should be able to simply connect them in parallel.
