Is anyone know what is the equivalent IC of UM91214B and KT3170??UM91214B is dual tone multi frequency(DTMF) generator.KT3170 is a DTMF to BCD converter. What is the manufacturer of those IC? Where can I get them? Thank you.
UM...is from United Microeledtronics Corp.,KT.. from Samsung,but discontinued. For DTMF decoding i recommend MT8870 from Zarlink.
UM91214 have stand-alone feature:the mixed tone+pulse redial. If You don`t need these function, use MT8880. |
Have a look at the posts in.........
http://www.electro-tech-online.com/viewtopic.php?t=576 It might help. :lol: |
If you don't find the above mentioned ICs for DTMF generation, you can also use UM95089. And CM8870 for decoding.
"There is no way to peace, peace is the way!" |
hi all,
does anyone know how to interface UM91214B to a computer. cant i directly connect it. also is there any difference between UM91214A and UM91214B ? please dont suggest any other dtmf chip as none else is available here. thx in advance Pradeep K. Shima
Its not the Practice that makes a man perfect. Its the Man who makes the practice perfect ----- Pradeep K. Shima ----- |
Connect the switch inputs of UM91214 to the data pins of your parallel port. Give proper 1 and 0 signals to these pins as if you are simulating a matrix key-pad. Thats it. Nothing more is required.
hi kinjal,
u mean if i want row 1 and col 1 dtmf tone, i simply put 1 on both the row 1 and col 1 pin ? thx a lot, bye
hi kinjal,
u mean if i want row 1 and col 1 dtmf tone, i simply put 1 on both the row 1 and col 1 pin ? u sure. i read somewhere u r supposed to short the required row and col pins. this wud mean that some current flows into and out of the pins. wont that blow up the parallel port ? thx a lot, bye
You can make this only with optocouplers or analog switches. When a button pressed on a crosspoint, started a scanning, (outputs producing shifted phase square wawe) and this signal go to input.
