+ Reply to Thread
Results 1 to 2 of 2
Thread: VFD Stuf
  1. #1
    Someone Electro Newbie
    Join Date
    Sep 2003
    Location
    A boring village in Europe (slovene)
    Posts
    2,601
    Default VFD Stuf
    I have a old VFD from a VCR and the only way i got it to light up is whith a sparcer from a lighter but i want o light it up whith normal DC
    Il give you shocking experience.
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    Default Re: VFD Stuf
    Quote Originally Posted by Someone Electro
    A VFD is basically a valve (tube), they work off high voltages and require a heater supply. Probably the best idea is to measure everything you can off the old VCR - some of them actually use a small inverter to provide both the high voltage and heater supply (often in a metal can - so it's easy to remove and use). You will also need high voltage drivers to feed it, bearing in mind most of them are multiplexed as well.
+ Reply to Thread
Tags for this Thread
