| Hi, I am designing an InfraRed link to tx and rx an analog signal over a distance of about 5m. Can anyone offer any pointers to cct diagrams or other resources I may use as a starting point for this project Thanks Stevo | |
Do you just mean a voltage reading?, or something like an audio signal? - and if so, what sort of bandwidth do you require?. | ||
| | (permalink) | ||
__________________ -------------------- -Gandledorf Come visit http://groups.yahoo.com/group/laser_design a group dedicated to help designers build electronic games, and design optical combat systems. | |||
| | (permalink) | ||
Stevo | |||
I'm also a little confused about your speeds? - 9600Baud is usually 9600bps, assuming normal 8N1 type protocols. Or is the vastly increased bps because of error correction added to the data?. 'Normal' IR remote controls work nowhere near that fast, usually only about 2400 or 1200 baud, and you can't normally just send standard serial data across them - you need some kind of coding, Manchester coding is commonly used. | ||
Yes you are correct, what I described was a digital signal, however due to the encoding and modulation mechanism it is presented to layer 1 as an analog signal. My original question probably should have been "What is the bandwidth of an IR link? Can anyone give me some pointers to good resources I can look up on the subject." 8) Regards Stevo | ||
| A good website for designig remote control applications would be: www.rentron.com You can contact their technical support for any question you have, there is a guy called Bruce, who is a calibre in this field. :!: I myself used the information there to design a Rx, Tx IR system from scratch. Itay | |
As Nigel said, you ideally need Manchester coding, but if you can ensure correct signal polarity at the receiver, then you can use baseband signals with normal start and stop bits. | ||
