Old 15th January 2004, 11:28 PM   (permalink)
Default flashlight with no batteries
hi guys! have u seen those flashlight with no batteries? they say it gets it power from induction and capacitors. sorry im a newbie and i really want to build one as a project. they are sold here (im from the Philippines) in a really high price. hope somebody could help me with the components' specification and how to build it. thanks in advance.
cowboytuna is offline
Old 15th January 2004, 11:59 PM   (permalink)
ok, ive found that this is a reapeted post. sorry for that, but the older post doesnt answer the question on how to build one. hope somebody could help. pls?
heres a link of the flashlight im talking about. its quite expensive when these are sold here: http://www.flashlight-forever.com/
Old 16th January 2004, 02:16 AM   (permalink)
It looks like magnet that can move inside tube when shaken.
You also have coil fixed arround the middle of the tube which
creates AC power when magnet flies by.
The text mentiones white bright LEDs as source of light.
This makes sense because LEDs are much more energy efficient.
I'd try to use maybe 4 of them wired in series.
I think I can see some electronics too. I would simply use just
the tiny bridge rectifier, relatively large el. capacitor and simple
constant current circuit for the LEDs.
The constant current circuit is easily made using resistor and some
active component. I would just use small LM317L with fixed
resistor of 56Ohm. That should give ca 1.2V/56Ohm=21.4mA.
panic mode is offline
Old 16th January 2004, 01:23 PM   (permalink)
thanks!! but what type of LED? is it the one that is used on cellphone backlight? or the one found on old car stereo. sorry im really new. but i think its the LED used on cellphone backlight? m i right? or is it another type of LED?? hope u could reply again.
thanks again. sorry for my dumb questions but i dont know somebody i can ask.
Old 16th January 2004, 01:27 PM   (permalink)
also whats LM317L? what type of wire should i use on the coil and how long should the coil be? i hope u could help me. pls.
should i put the circuit that u posted here before the LEDs or before the coil? i would really appreciate ur help. tnx in advance!
Old 16th January 2004, 05:16 PM   (permalink)
somebody pls help. thanks a bunch in advance!
matz is offline
Old 16th January 2004, 09:04 PM   (permalink)
OK, get back to basics...
First, the coil acts like a transformer, when a magnet is moved within it, it generates a current. This current will be alternating because the magnet will be moving in two directions. Hence you need a rectifier to control and change that alternating current into direct current...
Then you need to store it... a capacitor does this.
Have a look in Google for the LM317L. You will get what's called a PDF 'datasheet' on the device. The thought behind the LM317L is that it will allow the required current pass into the LED (around 20mA) and prevent a surge, because it will be very hard to control the voltage in this device!
So it goes:
COIL -> Bridge Rectifier -> Capacitor -> Current control -> LED.
The Capacitor will have to be very large, maybe 10,000uF and this may only provide 10 seconds of power to the 4 LED's if fully charged!
The bridge rectifier will ensure that no current is wasted, unlike a half or quarter wave rectifier.
Hope this helps...
McGuinn is offline
Old 17th January 2004, 12:44 PM   (permalink)
ok. thanks so much. that really did helped. one last question, why does it only last for so seconds while the commercially available ones last longer? did they put something else.
i really appreciate ur post. thanks so much.
Old 17th January 2004, 03:23 PM   (permalink)
To be honest, I'm not sure. The maths may work out differently...
I think you will have to play around with it to see. More capacitors will increase the time, but the coil will have to be quite efficient.
I haven't seen one of these things. How many shakes do you have to give it, and how long does the light last?
McGuinn is offline
Old 17th January 2004, 04:39 PM   (permalink)
They probably use even larger capacitor. Some things like one of
my multimeters do not have bateries. They use capacitors in farad range
(not micro or milifarad). However, most of the supercaps I've seen are
for low voltage. Maybe they use OLEDs so current consumption is lower,
although I dont remeber seeing white ones.
Old 17th January 2004, 04:52 PM   (permalink)
it needs 30sec of shakes or 3shakes per second or 90shakes in particular. they say it would give u 20 minutes for light with 30 seconds of shake. thats why im a bit surprised that it can only last for 10 seconds. got any other ideas??
the site also says that there are opposite magnets at each end which are align to repel the moving magnet.
Old 18th January 2004, 05:06 PM   (permalink)
any ideas guys?
Old 18th January 2004, 05:33 PM   (permalink)
The formula for working with capacitors is C=I*T, where C is the capacitance in Farads, I the current in Amps, and T the time in Seconds.
So for 1200 seconds, at 1A, you would need 1200 Farads. Even at 10mA you would need 12 Farads.
It would be interesting to take one of these apart and see what's inside it!.
Old 18th January 2004, 10:49 PM   (permalink)
The site gives us a picture of one of the lamps:
http://www.nightstar-flashlight.com/...lashlight.html
Note the size of the coil in the body of the unit, and a lack of visable caps!
IMHO, it's a very sloppy website...
McGuinn is offline
Old 19th January 2004, 03:48 PM   (permalink)
yea, im really interested in these things. its intriguing for me. :roll:
