Old 12th January 2004, 07:43 PM   (permalink)
Default Battery / Voltage Regulator
Hello everyone....
I really need to build a voltage regulator and i need ur help and ideas about any kind of design...
Basically, i need a voltage regulator from 36V battery to 24V
Thanks in advance
danos is offline
Old 12th January 2004, 07:52 PM   (permalink)
Default Re: Battery / Voltage Regulator
Originally Posted by danos
Hello everyone....
Thanks in advance
What are your current requirements? A 78L24 can produce 24V @ 100mA. An LM317K can produce between 1.2V and 37V @ 1.2A. An LM317T can produce between 1.2V - 37V @ 1.5A. An LM338K can produce between 1.2 - 33V @ 5A.
-Gandledorf
Come visit http://groups.yahoo.com/group/laser_design a group dedicated to help designers build electronic games, and design optical combat systems.
Gandledorf is offline
Old 12th January 2004, 08:12 PM   (permalink)
From what i know should be a bit more than the 5A
might be 6 or 7A
Sorry, i forgot to mention!!
Thanks for ur reply
danos is offline
Old 12th January 2004, 08:22 PM   (permalink)
You can use any of the above with an external pass transistor. Check their datasheets. That would be a whopper of a transistor, though, because you're looking at 84 Watts of power dissipation just across the transistor. Think "switcher."
j.
John Sorensen is offline
Old 13th January 2004, 11:39 AM   (permalink)
L4970 is a 10A switching reg. from ST.
Sebi is offline
Old 13th January 2004, 12:42 PM   (permalink)
Default Power Supply
Sorry, I made a mistake....
Regards
IRQ57 is offline
Old 13th January 2004, 10:26 PM   (permalink)
36 volts,
sounds like three 12 v batteries to me.
the easy way would probably be to
put the wire on to the 24 v connection.
simple and effective.
john1 is offline
