| I have some questions on using a microwave transformer as an invertor.I found the diagram and have all the pieces required.My questions: will the diagram below make 15 Amps of 120? or will i needed to upgrade some of the parts? I read the constrution remarks on building /using the microwave transformer (as T1 in the diagram) but still am not quite clear on how to build it .I know that you have to remove the 2000 v secondary and rewinded it with 12 turns of heavy wire and twist a loop (center tap)and then 12 more.But I don't know how heavy the wire should be and what is a center tap? My transformer has a primary winding,a field winding,and a secondary winding.do I just remove the field winding? OR?? Any help would be greatly appreciated. | |
| If you need 120 Volt x 15 Amp. (=170 Volt piek) The 2N3055 has to supply 14 x 15 Amp ( 1/2 wave) if the inverter should work at 100 % eff. 2N3055 is not able to supply 200 Amp ! Maximum 10 A piek. | |
| So how many 2N3055 would I needed? Or is there a bigger, better transistor to uses ? any help? | |
| I don't think that this is a good project for high power. here is another approch: http://home.t-online.de/home/Wolf-GuenterG/inverter.htm | |
| took a look at the web page,little more work than I want to get into right know.I'd like to uses what I've got.If I make a multiable input Say 5 or 10 of them would this work? Below (with the red box around it) is the parts of the diagram that I would make 5 or 10 of and just hook them up in (stack them) on top of each other.What do you think? | |
You couldn't just duplicate the components in the red box, all the multivibrators would run at different frequencies - things would go BANG! big style!. The way to parallel it up would be to simply parallel transistors across the existing ones, with each transistor having it's own low value emitter resistor to ensure load sharing. However, the existing 180 ohm resistors wouldn't be able to supply enough base current for all the transistors, so would need reducing substantially - then the oscillator frequency would be wrong, requiring the capacitors changing. A self oscillating design isn't a good idea, and as I mentioned I'm doubtful it would work at all. A seperate oscillator feeding the output stages via drivers would be a better bet - preferably designed to arrange that both transistors are off before the next one is switched on. The design on the web link that 'looks a little complicated' looks pretty reasonable to me - anything dealing with these sorts of powers will destroy all the expensive bits very, very, easily - a lot of the circuitry is to help prevent that. I presume you are aware of the current something like this is going to take off 12V? - probably getting up towards 200A!. | ||
| Nigel,the web site I got the diagram from is www.aaroncake.net/circuits/inverter.htm could you take a look at it and give me any input .Thanks alot for your input on the above posting.I'm new to this type of thing and when I seen this diagram ,thought it would be a good first inverter project.After reading the web.site again it says the inverter CAN be construted to supply any where from 1 to 1000 watts and then down the page a little more it says that by using the parts in there parts list that the inverter can only supply 300 watts. | |
It also says at the bottom, that it's very tricky to get working, and I can't say I'm surprised. When you design anything, it should be easily reproducible - that design certainly isn't. | ||
| | (permalink) | ||
A simple digital circuit can provide clean predictable gate drive signals. Just my .02 | |||
