I am trying to build a simple seismic circuit to measure the amount of vertical motion in the floor as people walk by my cubicle at work. I bought a geophone (a magnetic sensor that measures resistance between two magnets and thus measures vertical motion.) I want to interface this with my PC and so I am thinking of using either the Parallel Port, Serial Port, or possibly Game port of my PC to send in the data. At first I wanted to simply use the game port and connect the geophone as the Y axis of a joystick (since a joystick is simply a potentiometer that goes from 0 - 100K ohms). This did not work so well because the geophone at 5V only measures about between 1-2K ohms of resistance. I found a circuit on the net that converts the resitance to DC voltage between 0 - 5V.
http://www.eas.purdue.edu/~braile/ed...s/educseis.htm However, the PC interface costs $100 bucks and is not very cool. I wanted to build myself and so bought a ADC and found another circuit that converts the voltage to a binary number between 0 and 255. (8bit ADC) http://www.iguanalabs.com/adc2051.htm I am having trouble getting the ADC converter to work with my PIC 16F84A, but I think that I can figure this one out on my own. I was wondering if anyone new of a circuit that acts as a resitance multiplier so that if the output from the Geophone is only between 1k OHM and 2kOhm the resulting output of my circuit would be between 5K - 10K ohm or possibly 50K - 100K ohms??? I am a software guy and pretty new at hardware. I know how to program the PIC and I think that I can get it to work with my PC Parallel port once I figure out how to get a 10Mhz clock connected to my PIC in order to send the data from the ADC to the PC within 10us which is the time out for a read from the LPT data port. Thanks for any help!!! |
Super Moderator
It would be simpler to use the PC serial port - and more than fast enough for what you want.
You don't need a resistance multiplier, all you need is a voltage amplifier (easiest using an op-amp) - the A2D needs a voltage, not a resistance. To generate a voltage from the changing resistance you could simply connect it in series with another resistance across the supply rails - the voltage at the midpoint will then vary as the resistance varies. For a somewhat 'nicer' design, incorporate the sensor in a Wheatstone bridge circuit and use a differential amplifier. To simplify the PIC side you could also use one with in-built A2D, many of which are 10 bit (rather than 8 ) - the 16F819 is 18 pin, like the 84, but includes A2D. |
Thanks Nigel! The circuit that I have currently converts resistance to voltage for the ADC. I didn't know anything about PICs when I bought my programmer so I just bought the intro programmer which came with the 84A so I have stuck with that. Had I known more I would have bought a PIC with builtin ADC and UART which would have made things really easy. I basically interface the circuit from this link and pass the input into the ADC which is set up to interface with the PIC.
http://www.eas.purdue.edu/~braile/ed...s/educseis.htm The circuit that I have uses an OP amp to amplifier the signal, a potentiometer to adjust the voltage approiately so that 2.5V will be output when the Geophone is at rest, and then another IC to stablize the voltage between 0-5V. I have downloaded the serial code for from your tutorial page and I plan to use that to send my bytes to PC, however it is slightly easier to send the data to Parallel port because then I don't have to worry about sending over serial and I don't need to interface with a MAX232 in order to convert to the correct voltage levels of -10V/10V. Thanks for the suggestions, and for all of the samples and tutorials from your website. Once I get the thing to work I will post my completed work!!!! |
(permalink) | ||
Super Moderator
To use the parallel port you would have to write code for both ends of the link, depending how you did it - either as serial through the parallel port, transferring data as 4 bit 'nibbles' (using handshake input lines), or using the port in an 'enhanced' mode EPP etc.[/quote] |
Experienced Member
Thanks for all the useful info from your posts, which resulted in my memory bank gaining a few extra MB of info (approx 450%)...
I found this topic extremely interesting and now need to get a geophone for myself, but I dont have a clue where to start looking... please help... |
YOu can get a geophone from several places. Search Ebay for Geophone and you can get a kit that comes with a geophone and a simple circuit that simply lights up a LED when vibrations are sensed. Here is link to a guy that sells kits for $10 dollars.
http://members.ebay.com/aboutme/alexandracarter/ I bought mine from www.electronicskits.com, but they have stopped selling the kit. Hope this helps!!! |
Now I rember that I got my kit from BGMicro. They sell the kit for 17.95, here is the link:
http://www.bgmicro.com/prodinfo.asp?...time_out=19:57 If all you want is a geophone, I would get the cheapest one I could find, which most likely will be on ebay. |
Nigel thanks alot for all your help!!!! Serial really prooved to be the correct form of data transmission because Parrallel port was too difficult to syncronize with my circuit. I got my graphing software up and running yesterday and the guys here at work really enjoyed seeing people walk past our cubicles and make the graph really move. I wrote my graphing application in C# using the .NET framework so that it runs well on XP. I used an article posted at MSDN to get the code to read the serial port, I will post link later, and then wrote my own Windows Forms custom control to do the graphing. I will post all of the code for both the PIC and my application as soon as I work out the bugs. I will also attempt to create a circuit diagram of the completed project in case anyone else wants to build it.
Right now I have all of my IC's, resistors, and PIC on two bread boards with lots of jumper wires. I wanted to put this circuit on a single board, but I don't know what the best process is for doing this. I know that you can buy perf-boards and then transfers, but how do you put the transfers onto the perfboard??? Also where is a good place to get the materials to do this??? I know that they sell some types of perf-board at Radio Shack here in the US, but are there better products (easier to use) available elsewhere or online? Thanks in advance for any information you can provide. |
Super Moderator
Many people create their own PCB's, either rubbing down transfers, or designing it on computer and using a photo process. Both board then need etching and drilling. I've never had the patience for this :lol: |
I just created my website for my Seismograph circuit. I included links to the software that I am using to display my graph on my screen, and some links on how I built my project. I hope to post a circuit diagram later this week.
http://www.wamail.net/~aevans/SeismoCtrl.html |
