Old 6th February 2003, 12:40 PM   (permalink)
Default anologue to digital converters...
can anyone help me with these? i dont need help with PCM anymore. ive researched a lot and broken it down into its blocks. though i do need help with A/D conversion. can anyone help me with a circuit diagram or basic component list? thnx guyzhse! 8)
why do kamikaze pilots bother to wear helmets?
chimpsimply is offline
Old 6th February 2003, 05:37 PM   (permalink)
ADC0804/ADC0820 will be easiest to use. These are 8-bit ADCs with quite good performance at medium speeds.
kinjalgp is offline
Old 6th February 2003, 05:39 PM   (permalink)
I'm a believer in the old concept of 'Teach a man to Fish...'
The method most of us use is to first find a chip which will suit the application, download the datasheet, and use the sample circuits to build what you require. An 8-bit ADC would be best to start off with.
For example, "ADC0804LCN" is such a chip and looking in www.maplin.co.uk will get you a circuit for this device.
Simple as that!
McGuinn is offline
Old 8th January 2005, 07:22 PM   (permalink)
what's the different between analogue ground and digital ground
life is so short, don\'t waste your time dude
denidoank is offline
Old 8th January 2005, 07:26 PM   (permalink)
Simply to help prevent digital noise from entering the input of the A2D, you should design your PCB accordingly - keeping analogue and digital sections as seperate as possible.
Old 8th January 2005, 11:04 PM   (permalink)
and then connect the two GNDs (digital and analogue) at one low-imedance point (star-point) to the main power-supply GND.
Styx is offline
