Old 31st December 2003, 11:48 AM   (permalink)
Default three phase genarator
a problem with a project:
create a electronic circuit that can keep still tha output voltage of a three phase genarator,with out carrying for the resistanse, requlating the current.
tips:
a)when the genarator is not spining the current must be zero
b)the current must not be higher than 5A
any thoughts??????thnks
tsoupl is offline
Old 1st January 2004, 02:38 AM   (permalink)
Is the alternator delta or wye connected? Does it have a balanced 3 phase load? If the load is balanced, you only need one current transformer, otherwise you need 3.
Russlk is offline
Old 2nd January 2004, 10:40 AM   (permalink)
as i know is the wye connection,and yes it has a 3 phase load!!!!
but wat about the electronic circuit that controls the output voltage of the genarator??
tsoupl is offline
Old 2nd January 2004, 02:25 PM   (permalink)
This site has some info: http://www.john-joyce.co.uk/electron/altoreg/
Russlk is offline
Old 3rd January 2004, 07:02 PM   (permalink)
What type of generator are you building? (e.g. synchronous or induction)
Does the generator need frequency and control?
Since your generator is very small (i.e. you will not upset the system grid) you can easily control your output voltage by connecting your generator to the infinite bus. (same thing goes for frequency and phase).
Can you be more specific in asking your questions so that I can specifically address them?
pop is offline
Old 3rd January 2004, 09:36 PM   (permalink)
it`s a sychronous generator!
the frequance that works to is 50hrz!!and what is asked circuit that can requlate the output voltage of the generator!
what do u mean with the infinite bus???
tsoupl is offline
Old 4th January 2004, 04:21 AM   (permalink)
I don't know why some people are so stingy with information. Let us assume Tsoupl has a wind powered alternator, and he can adjust the power input by changing the vanes of the windmill. Then what is needed is a current transformer to measure the output and a servo to move the vanes. The voltage and frequency will be fixed by the grid but the alternator can burn up if power input is not controlled.
BTW, what is the difference between a synchronous and induction alternator?
Russlk is offline
