| what if I got back to the old 19 V supply , would that help? | |
| because I tried it without a heat sink and it worked oK , it began to heat up but did not loose current , in addition I am using now two heat sinks taken from a PC case power supply | |
| no you did not understand me, although getting hot it did not shut down, it only shut down when i used the 30 V DC for IN ! | |
A 7812 regulator can dissipate a max of only about 2W when it does not have a heatsink. If the transistor is working properly and the circuit is designed properly then the regulator would get warm on a small heatsink and the transistor would be pretty hot on a big heatsink.
