| Hi everyone... Here is my problem.I have designed a few basic power supplies (+/-15 volts for some op amps and a basic power supply using an LM317). Recently we have been asigned to design a power supply(low power) with an output of 2-12V/1A using PWM modulation. Am i supposed to controlt the PWM duty cycle using thyristors?Is there a PWM ic? Plz some help and if anyone one has a link for an actual schmeatic as all i can find is schmeatics for linear power supplies... Thnx :idea: :lol: | |
| You can use a "Simple Switcher" buck regulator from National Semi or ON Semi. | |
| Thnx...Hopefully those ic's will be available in the greek market | |
| Do u think i could use an Lm555 with a normal power supply fot the PWM modulation? | |
| Just find a old AT/ATX powersupply or any switching PS, you will have the TL494 or the C3580. 70% using this IC's. STEVE | |
| Thnx for the info...Ill post my final schematic probably by Monday :wink: | |
