Old 13th December 2003, 06:55 AM   (permalink)
Default cd4066
i would like to use the CD4066 which is a quad bilateral switch as an audio source selector.
my question are the following:
1. is this device suitable for such an objective?
2. does this device degrade or introduce noise to the original signal?
your reply would be highly appreciated.
thanx :lol:
\"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~
mozikluv is offline
Old 13th December 2003, 08:20 AM   (permalink)
1. Yes, it is suitable for audio applications, provided the maximum signal voltage swing remains within the rail voltage.
2. No, It introduces no noise. You can even switch low level mic inputs with it.
pebe is offline
Old 13th December 2003, 06:58 PM   (permalink)
also you should take in consideration that it has a resistance, and that the current allowed trough it is not very hight.
from what i know, it does not induce noise.
bogdanfirst is offline
Old 13th December 2003, 07:34 PM   (permalink)
Yes, this resistance is usally in the range of 100 ohm's. If the input of the device you are trying to switch is low impedance (75 ohm for example) this can cause problems.
If it has a high impedance input then the few ohm's extra won't make a diffirence
Exo is offline
Old 13th December 2003, 10:01 PM   (permalink)
With a supply rail of 7.5v the 'on' resistance of the switch is around 75ohms, and that is rarely found as the source or load in modern audio equipment. 75ohms is the normal impedance of coaxial-fed TV RF circuits, whereas the audio standard was (originally) 600ohms balanced line.
Nowadays, because of the influence of Japanese equipment designers, these stanards have been ignored and the source impedance of most audio equipment tends to be in the region of 10K to 50K. Under those conditions, the 4066 resistance can be ignored.
pebe is offline
Old 14th December 2003, 06:17 AM   (permalink)
Pebe wrote:
I think Pebe meant to say input impedance, not source impedance. Source impedance is generally much lower and irrelevant to this discussion.
Roff is offline
Old 15th December 2003, 06:31 AM   (permalink)
Default 4066 bi switch
thanx guys for the replies.
MERRY CHRISTMAS TO ALL OF YOU!!!!!!!!!
mozikluv is offline
Old 17th December 2003, 12:03 AM   (permalink)
Originally Posted by Ron H
You're quite right, Ron. I must have misplaced my brain at the time!
pebe is offline
