I need circuit diagrams and ideas for constructing battery operated
cigarette lighters and battery operated lighters for lighting gas ovens. A single 'AA'should be used for the above lighters. Please help. Thanking you ks_raman |
Experienced Member
well for lighting a gas you could use an inverter to generate high voltage adn a spark, but for lighting the cigarette you need some resistance to heat the cigarette unti it lights.
Experienced Member
A heating element may prove difficult, using only a AA battery, as a AA will provide, at most, a few watts. It doubt it can produce enough power to heat an element to 200 degrees, (unless it is a VERY small element :lol: )
Having said that - please go and prove me wrong. It would be quite interesting if it can be done. |
Super Moderator
You are right
"There is no way to peace, peace is the way!" |
Experienced Member
that i what i was saying it is easy to get high voltage to make a spark and light the gas, but you need a very small element to be able to heat it enough to light the cigarette, but i dont think you can get high power to light it, so it wont work,
Super Moderator
Well, I have seen handy electric-sealer for plastic bags (stepler like thing) which works on four AA batteries. It has a small heating element which heats up quite well but the batteries don't last long. So you can't say that its impossible to generate enough heat to light a cigerrate but the battery won't last long.
Experienced Member
but from what i remember, doesnt he need to use only one battery?
you know a "square battery"(i dont know what size it is, 4.5V one) can provide enough power,but none will last long enough. maibe use a rechargable one? |
Experienced Member
how bout using the laser thing from a ditched CD-Burner.
if it can burn a big CD, wont it burn a small cigerrate :shock: :?: the only problem is that it might be harmfull to the skin or eyes if stared at. but hey smoking is injurious to health anyway. so there u r raman. bye, Pradeep K. Shima
Its not the Practice that makes a man perfect. Its the Man who makes the practice perfect ----- Pradeep K. Shima ----- |
Experienced Member
"how bout using the laser thing from a ditched CD-Burner.
if it can burn a big CD, wont it burn a small cigerrate" The beam is focused to a very tiny spot to blow tiny holes in the thin metal layer. It will make a really super laser pointer, though. "battery operated lighters for lighting gas ovens" Convert the battery voltage to 300v, then increase it even further with a pulse transformer(I have made 1cm sparks by discharging a 0.1uf cap charged to 300v through the primary of a flyback transformer).
visit my website at http://www.geocities.com/star8823200...?1031500905870 Analog TV is dead! Long live digital TV. The floppy drive is dead! Long live the CD burners. |
Experienced Member
thats what i thought, but could you light it with a sprk and produce it from a single battery?
Experienced Member
spark isnt a problem then right ?
the problem remains that of creating a small fire to light the cigerate. y not put a tiny gas cylinder in the lighter just like normal lighters and use the spark to light that gas up ? the requirement is to have an battery OPERATED lighter and not a lighter composed entirely of the battery :!: :idea: :twisted: bye, Pradeep K. Shima
Experienced Member
how about a quarts cristal, to produce the spatk.? :idea:
Super Moderator
Same principle is used in Gas Lighters but what about the cigerrate one?
Experienced Member
kinjal,
c my last post on this topic. y wont it b able to light a cigrrete :roll: bye, Shima
I have searched internet in Google search engine with 'battery operated cigaratte lighters' and found so many products. But they use two AA
batteries. They are small. It can be carried in our pocket. How they work? You can find them at http://www.sailorrandr.com/web/novelty/bol.htm Thanks for all of you |
