Hi there, Interesting site. I want to us a hex NAND gate Schmitt to get a monostable pulse, a delay, and then two astable pulses from the same chip. Is this possible? Also, can I gate the two circuits so that the astable is switched by the monostable? I know the 555 is often used in this way, but the CMOS quiescent current is what I need for long-term battery use. Even the 7555 has a higher supply!
I need the monostable to be on for about one second, allowing just two pulses from the astable in this time.
The complete pulse chain I need is -
1) monostable on for one second
2) delay of about 1/2 second, no pulses (from a second monostable?)
3) astable giving two pulses of about 1/2 second each, separated by 1/2 second.
4) return to step 1 to await next trigger
I also have a question about NAND gate function. Why are TWO gates needed to make an astable on a standard NAND chip like the 4011, but only ONE gate on the 4093 and 40106 Schmitt NAND gates?
Thanks for your help,
Julian Silverton
. I got sidetracked by other things and never did get back to it.
