Old 26th November 2003, 09:05 AM   #1
Default pulse generator
hi
i also need help on making a pulse generator which could emit within 50 microsecond
any schematics would be appreciated
dark_conqueror
dark_conqueror is offline
Old 26th November 2003, 02:26 PM   #2
Default Pulse generator
Can you be more specific about your needs, as the component values affect the circuit operation. Do you mean 50usec as pulse width or 50usec
between pulses?
k7elp60 is online now
Old 27th November 2003, 05:58 AM   #3
Default Re: Pulse generator
between pulses?
oh sorry about that. what i meant was 50usec between pulse.
i used ic 324(operational amplifier) and managed to get the signal up to 100usec but the signal shown on the oscilascope is zig zag , which something i don't want .
i would prefer the output would be in square waves
cheers
dark_conqueror
Old 27th November 2003, 10:50 AM   #4
between pulses?
cheers
dark_conqueror
So now we know the space width, but not the pulse width
In any case, an operational amplifier isn't a good choice, you really need a digital chip - or even a simple micro-controller. A PIC running at 4MHz takes 1uS per instruction, or at 20MHz only 200nS per instruction, you can easily generate 50uS (and smaller) pulses.
What is your actual application?, knowing that might make suggestions more applicable.
Old 28th November 2003, 04:28 AM   #5
hi
thanks for the reply
i am making a high speed counter to count the lag time during zero crossing between 2 sinousidal.
i was thinking of using and AND ic with the output from a compilator and a pulse generator with the output connected to a counter .
will this work?
d.c
Old 28th November 2003, 04:40 PM   #6
If I understand you, you want to count the time between two sine waves.
I would use two comparators, one to start the count and one to stop the
count. The count in seconds, milliseconds, or useconds is the period of time between the two sine waves.
Old 28th November 2003, 10:25 PM   #7
If you square up the sine wave using comparators and feed that into an exclusive-OR gate, the output pulse will be proportional to the phase difference. You can filter that to DC for an analog output (I prefer analog solutions).
Russlk is offline
