| Hi, I'm trying to build sensory units for monitoring purposes. The sensors could be security indoor type (i.e. sound, light) and safety (i.e. smoke detector, gas, temperature, humidity). Does anybody has the circuit for any of these sensors? Thanks. | |
__________________ \"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~ | ||
| I am also looking to build a sensor circuit. One that will monitor heat in my computer system. It may control fan speed and add some additional fun blinking lights. I know it may seem lame, but I figure it is a good introductory project. I don't currently have the circuit designed, but plan to work it out as I get more parts and ideas. I'm sure that I will be sending my ideas here before I put them together. So far I have the basics: Heat sensor to a heat comparitor chip that sends a signal to an altera chip that decodes the digital signal to seven segment LEDS, or colored LEDs that can tell actual temp or change color with temp change. Hope to see your ideas as well. Maybe they will give me more ideas. | |
| Go to google.com and search for: case mod sensor case mod detector case mod leds case mod circuit case mod baybus case mod altera case mod control etc. etc. etc. Resc. | |
| Hi, I've tried see the rest of the post.. but I don't find it quite relevant... I need a simple circuit that definitely will work while so far I got complicated ones. Thanx! | |
