| I would like to use 6vdc 50ma to activate a solid state relay. On the internet I found a relay....the specs are listed below. Is 6vdc 50ma is enough electrcity to activate the relay? How much millamps would this relay require at 6vdc? DC/DC Solid State Relay Screw terminal with hardware Photo isolation Metal mounting base Control Voltage: 3-32VDC Type: DC/DC Contact style: SPST Contact Voltage: 60 VDC Contact Current: 2A Pins: 4 Terminal Type: Solder lead Size: 1.4"L x 0.3"W x 0.9"H | |
| Since it is a solid state relay with photo-isolation, it doesn't require much current to activate. It will require same current as an IR LED would require i.e. around 10-15mA maximum.
__________________ "There is no way to peace, peace is the way!" | |
Thanks for your reply | ||
| Posting the specs is good. Posting a link to the datasheet would be better. | |
http://www.jameco.com/cgi-bin/ncomme...s=503;523;722; | ||
6V 50mA means your source can supply 50mA @ 6V to a load which requires it but that surely doesn't mean that it will force 50mA into whatever load is connected. The current drawn will depend upon the resistance of the load.
__________________ "There is no way to peace, peace is the way!" | ||
| I agree with Ron. The SSR input contain a FET current generator, so the input current from 3 to 32V only 3mA. | |
I originally got the 3ma number by simply reading where the line passes through 6 volts. | ||
