Old 18th January 2003, 03:02 AM   (permalink)
Default DIGITAL MODULATOR CIRCUIT
I need a circuit that I can take an 8 bit digital data signal and modulate it
onto a standard telephone line, and if possible a second circuit to demodulate the signal to recover the 8bit data, I would like these circuits
to be easy to construct
I need a circuit that can take an 8bit digital signal and modulate it onto a standard telephone line, and then a demodulator circuit
to recover the data---I want this to be an easy
to assemble project! --can anyone help!!!
TDE is offline
Old 18th January 2003, 04:34 AM   (permalink)
For 8-bits or more you'll require a complete MODEM on both ends of the telephone line. No other smaller alternative.
If you want only 10-12 numbers to be transmitted/received, you can use UM91214 DTMF generator and KT3170 DTMF decoder ICs.
Remmber, hooking up anything to your telephone line without permission of telephone company is illegal.
kinjalgp is offline
Old 18th January 2003, 03:47 PM   (permalink)
why dont you try to use a parallel to serial converter and then on the other end a serial to parallel converte?
bogdanfirst is offline
Old 19th January 2003, 03:51 AM   (permalink)
Without modulation data can not be transmitted over telephone line. Even if you Serial to parallel and parallel to serial converters, MOD/DE-MOD will be required.
kinjalgp is offline
