Old 16th November 2003, 06:19 PM   (permalink)
Default Debugging LM 317 Regulator
I am trying to build a variable powersupply using LM 317 IC. The input DC voltage (after rectification) is about 26 volts. However, at the output I am getting voltage from 1.2 V to 6.2 V only. What could be the reason?
Thanks and Regards,
amy_pur
amy_pur is offline
Old 16th November 2003, 07:28 PM   (permalink)
Post your circuit -- but you might not have the right values for your resistor and potentiometer.
The equation is V=1.25(1 + R2/R1)
R2 goes from the adjust pin to ground and R1 goes from adjust to the output. R2 should be about 200R1 or thereabouts.
crust is offline
Old 16th November 2003, 08:37 PM   (permalink)
Try replacing potentiometer for bigger one, it sounds like you have 1kOhm only. Use 5kOhm.
panic mode is offline
Old 17th November 2003, 06:12 PM   (permalink)
Thanks. Yes, I have used a 1 KOhm potentiometer. I will change as suggested and check.
amy_pur is offline
Old 17th November 2003, 06:17 PM   (permalink)
Thanks Crust. You are right, the current ratio is (R2)1000 Ohms : (R1)220 Ohms. As suggested by another friend, I will change the POT value to 5000 Ohms. This should solve the problem.
amy_pur is offline
