+ Reply to Thread
Results 1 to 3 of 3
Thread: Motion Sensor Alarms
  1. #1
    Deepan Newbie
    Join Date
    Oct 2003
    Posts
    8
    Default Motion Sensor Alarms
    Hi, I am in my final year of elecrtonics at college and I need help on my project for this year. My project, as you can see in the subject box, is a motion sensor alarm.
    I need some basic information on the sensors I can use. I think there are two types of sensors I can use, which are PIR (pyroelectric infrared sensor) and Passive-Optical Person sensor. Can you please give me links or basic knowledge on how these devices work. I would be very much appreciated. ...
  2. #2
    john1 Good john1 Good
    Join Date
    Jan 2003
    Location
    RW
    Posts
    1,249
    Hi Deepan,
    Motion sensor.
    If your electronics examiner would be happy for you to purchase
    the chips and solder together the support circuitry, then a
    passive infra red unit would be very easy to make.
    However on the other hand if your electronics examiner actually
    expects you to design and build a motion detector using general
    type chips, and/or regular components, then i would suggest that
    a 'sonic echo' type might be easier to construct.
    In case you don't know the principle, it relies on doppler shift.
    A note is produced and sent out into the air with a small speaker
    or tiny transducer.
    All the returning sound within about ten percent of the original
    frequency is amplified with the original frequency removed.
    Any movement makes echoes which are only slightly different in
    frequency to the original, and its these which cause a response
    from the unit.
    These units used to be fairly common, but you don't see them much
    now. The construction is basic, and fairly easy to understand.
    The electronics involved in a passive infra red sensor is a higher
    level of complexity.
    After looking around a bit, i found this:
    http://www.ee.washington.edu/consele...l/proposal.htm
    Which describes a project very similar to the one you outlined.
    It gives an excellent explanation of the 'Ultrasonic movement
    detector'
    I was very struck by the simplicity of construction of their
    proposed infra red motion detector, until i read through it again.
    Then i realised its only a beam.
    Their sensor responds to the interruption of a beam.
    I don't think that is quite what you have in mind.
    A PIR motion detector seems to be quite an involved electronic
    system,
    http://www.holtek.com.tw/pdf/consumer/761x.PDF
    even putting together the support components looks quite difficult.
    Best of luck with it,
    John
  3. #3
    Deepan Newbie
    Join Date
    Oct 2003
    Posts
    8
    Thanx for the help john. :lol:
+ Reply to Thread
Tags for this Thread
