Old 12th November 2003, 07:03 PM   (permalink)
Default project for trigger pulse so as to have fase control
i was given a project at my university and i need some help.the project says:" find a trigger circuit (control unit making a trigger pulse,using anything u want UJT,Transistors,DIODOS,Microcontroller or even IC)that will give a pulse to a thyristor or more, so as to have fase control.it would be helful if you give the hole circuit,starting from the power supplie to the Lamp or the work that will do.if u use microcontroler it is needed to have the progam that is needed for it to work."
so if anyone cold help me i would be graidful
tsoupl is offline
Old 13th November 2003, 01:09 AM   (permalink)
Here's a lamp dimmer project using a PIC12C508 chip. Everything's served to you in a silver platter.
http://www.microchip.com/download/ap...gns/40171a.pdf
"Having to do with Motion Control"
motion is offline
Old 13th November 2003, 02:18 AM   (permalink)
Default Re: project for trigger pulse so as to have fase control
you will need the microcontroller or similar circuit for generating the phase control signals. Is this for something like a synchronous rectifier or motor-drive circuit? Power electronic texts will give you some help on the devices you mentioned above. While there is alot out there on the net for doing this, don't you really want to design one yourself so you can better learn from it?
Optikon is offline
Old 13th November 2003, 12:51 PM   (permalink)
Yes,i could but it`s very difficult for me because i don't know well to program microcontrolers as i know only assemble and not any software programing program for microcontrolers or plc.So i need help!any project that uses fase control is helpfull.
now for the picdim lamp dimmer,is very helpfull,but can it work on 220voltAc and 50Hz?(thnk u very much motion).
tsoupl is offline
Old 13th November 2003, 07:50 PM   (permalink)
Hi tsoupl, why dont't you sent me that problem (from Prekas )a bit more analytically so that i can check if i have anything to give you or try to search a bit myself?
giannisasp is offline
