+ Reply to Thread
Results 1 to 3 of 3
Thread: 556 Delay
  1. #1
    dr.p737 Newbie
    Join Date
    Nov 2003
    Posts
    1
    Default 556 Delay
    I need an LM556 to make two delays to two different outputs using the same trigger. I guess I just hook the switch to both trigger pins. My problem is in how to get the timer to delay an action instead of time an action. I need a fifteen second delay before a buzzer sounds and a twenty second delay before a motor turns. Neither action needs to last long. One second would be long enough. The motor would turn five seconds after the buzzer sounded. How do I wire a 555 to delay an action instead of time an action? Any schematics would be helpful.
    Daniel Ramsey
  2. #2
    CraigC Newbie
    Join Date
    Oct 2003
    Posts
    9
    I was wondering if you had worked out the answer to your problem.
  3. #3
    mozikluv Newbie
    Join Date
    Aug 2003
    Location
    Philippines
    Posts
    372
    Default Re: 556 Delay
    Quote Originally Posted by dr.p737
    I need an LM556 to make two delays to two different outputs using the same trigger. I guess I just hook the switch to both trigger pins. My problem is in how to get the timer to delay an action instead of time an action. :? I need a fifteen second delay before a buzzer sounds and a twenty second delay before a motor turns. Neither action needs to last long. One second would be long enough. The motor would turn five seconds after the buzzer sounded. :? How do I wire a 555 to delay an action instead of time an action? Any schematics would be helpful.
    Daniel Ramsey
    am abit confused with your post, but let me clarify something;
    1. what you need is on delay timer, right?
    2.where does the 1 second time fit in
    3. the motor turn on delay is 20s and the motor would run for 5s, is that right?
    4. is this a one shot action or a self retriggering action [/u]
    \"NONE BUT THE BRAVE DESERVES THE FAIR\" ~Shakespeare~
+ Reply to Thread
Tags for this Thread
