+ Reply to Thread
Results 1 to 6 of 6
Thread: Boost Converter and switching losses
  1. #1
    yuchween Newbie
    Join Date
    Jul 2006
    Posts
    24
    Default Boost Converter and switching losses
    Hi, anyone knows why my switching losses of my boost converter is too high?
    i have a boost converter that its output voltage should be regulated at 388VDC.
    However, my circuit works with very low efficiency, when my load is 70W, and i put in input voltage of 80W, there is no voltage regulation. In fact, the output votlage dropped to 288VDC.
    input voltage was 80W and output voltage was 40W, which means the remaining 40W was switching losses. I am wondering why? The voltage feedback loop is working fine.
    The boost topology has this formula, Vout/Vin=1/(1-D)
    However when the Duty cycle is too high, out Vout will saturate at a point. so when the output voltage saturates, will it cause high switching losses?
  2. #2
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Post a schematic. You'll get better/more answers that way.
  3. #3
    yuchween Newbie
    Join Date
    Jul 2006
    Posts
    24
    Default Schematic
    my circuit i am working on is actually a power factor correction rectifier circuit connected to a converter.
    I obtained unity power factor but not voltage regulation. So i think the problem in my circuit is on the dc-dc converter.
    As Duty cycle of the mosfet increases, the switching losses will be higher?
  4. #4
    Diver300 Excellent Diver300 Excellent Diver300 Excellent Diver300 Excellent
    Join Date
    Oct 2007
    Location
    England
    Posts
    1,102
    It would help if you added the component values that you are using. What are you supplying Vcc from?
    Also voltage is measured in Volts (V) and power is measured in Watts, W so
    Quote Originally Posted by yuchween View Post
    doesn't really make any sense.
    You should tell us what the input voltage and current are, and what the output voltage and current are.
  5. #5
    yuchween Newbie
    Join Date
    Jul 2006
    Posts
    24
    Sorry was my mistake. I meant was input power and output power.
    In Watts.
    I dont think those values do much in my question. I just like to know when the duty cycle of the converter saturates, means if the duty cycle increases, there will no longer be any increase in output voltage.
    Boost converter voltages are governed by this equation:
    Vout/Vin=1/(1-D)
    When D further increase beyond 0.8, the boost level will saturate. During that saturation, will the switching losses increase drastically?
  6. #6
    MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent MrAl Excellent
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    1,293
    Hi there,
    I dont see a lot of details here either, but it sounds to me like maybe either
    the inductor is saturating or the power transistor does not stay 'on' long
    enough to supply the required energy to the inductor.
    To check this out, you need to calculate your peak inductor current and
    the resulting output current and voltage and see if the transistor can stay on
    long enough for the right output. If this checks out, then check to see if
    the calculated required peak inductor current exceeds the rating of the
    inductor. This should get you 99 percent there.
    You can find the equations for boost circuits all over the web.
+ Reply to Thread
  1. boost converter
    By justDIY in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st January 2008, 12:11 AM
  2. boost converter help
    By teksaport in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th December 2007, 08:04 PM
  3. Switching Boost Regulator + Current Source
    By freeskier89 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th December 2007, 05:14 AM
  4. Calculating losses in a DC-DC converter.
    By jrz126 in forum General Electronics Chat
    Latest: 31st July 2007, 04:21 PM
  5. boost converter
    By ee01akk in forum General Electronics Chat
    Latest: 13th April 2004, 06:52 PM
Tags for this Thread
