What's wrong with just using a 250 ohm resistor?.
Please can someone suggest me an alternative to IC 741 in the basic V to I converter and non inverting amplifier circuit as we require an opamp which uses only a single supply.
The input to V to I converter is 0 to 5 volts and output is 0 to 20 milliamperes.
the output of amplifier is 0 to 5 volts.
"Nigels Asm tutorials:" www.winpicprog.co.uk/
"Ian Rogers 'C' conversion of Nigels Asm tutorials:" http://www.electro-tech-online.com/c...torials-c.html
Because it isn't a normal standard value?
Nevertheless it can easily made by connecting 240Ω and 10Ω in series or just use 249Ω which is a 2% value and is only 0.4% out in this case.
However it seems like a pretty common thing to do so it wouldn't surprise me if you can buy 250Ω resistors specifically made for the purpose
You can buy HS 250R's
http://www.rhopointcomponents.com/pr...partno=H1L45AL
Or LM358, if you just want an 8 pin DIP.
One problem with using a 250Ω resistor is that it drops 5V which might not be acceptable.
Just use a 10Ω resister and a non-inverting amplifier with a gain of 25 and it will drop just 200mV.
http://en.wikipedia.org/wiki/Operati...lifier_circuit
R2 = 240k
R1 = 10k
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| is it possible to use single supply for opamp | saran | Electronic Projects Design/Ideas/Reviews | 5 | 5th August 2009, 10:42 AM |
| Techniques... Making a Dual Supply from a Single Supply | Ayne | Electronic Projects Design/Ideas/Reviews | 49 | 1st February 2009, 02:06 PM |
| opamp audio mixer - single supply | fvnktion | General Electronics Chat | 7 | 11th July 2007, 07:16 PM |
| Split rail supply needed from single 12v supply | johneaston | Electronic Projects Design/Ideas/Reviews | 13 | 17th May 2007, 07:22 AM |
| Can this be done with just a single OpAmp and resistors? | dinofx | Electronic Projects Design/Ideas/Reviews | 11 | 9th January 2006, 09:20 PM |
