Old 25th September 2008, 01:34 AM   #1
Default power distribution question.
Hello. I am an artist making a sculpture. I am incorporating 9 solenoids with leaf switches into it, as well as activating it all with a motion sensor. All are 115 VAC.
My question is this.
I am trying to figure out how I want to wire all these together. I am wiring a wall plug directly to the motion sensor, and from there wanted to use a sort of distribution strip to send power to the switches/solenoids. I was thinking of using a couple ground bars like you would see in a distribution box for a house. One for hot, one for neutral.
What are the thoughts on this? should it be ok? or should i just wire them in series?
THanks in advance for any help you all can provide.
derek.w.russell is offline
Old 25th September 2008, 01:41 AM   #2
Originally Posted by derek.w.russell View Post
9 solenoids
All are 115 VAC.
AC solenoids might audibly hum. Running them on filtered DC would be noiseless.
Willbe is offline
Old 25th September 2008, 01:44 AM   #3
the solenoids will only be switched on for a split second, sort of like the solenoid that pops the golf ball back in an automatic putt return. so hum is negligible to the project.
Old 25th September 2008, 03:38 AM   #4
You should not put them in series unles you have 220V then you can put 2 (115v)solenoids in series
switchem all in parralel and as you sugested you can use strips/bars to make the conection word of advidce is that put the strip/bar in a box isolated from curious children fingers and or animals and a small mcb of 6 amp wouldn't hurt either Also not your wallet but see it as an optional, not an essential
Robert-Jan
rjvh is offline
Old 25th September 2008, 04:03 AM   #5
that's kinda what i thought. thanks for the help. I think I'll bypass the mcb for now, as even though it's not too expensive, I have already put a little more money into this project than I originally intended to.
Old 25th September 2008, 04:14 PM   #6
Derek - you might consult an electrician directly for help on this especially if your work will be in a public place. My knowledge is very limited but at first glance I'd say you need three conductors - hot, neutral and ground. Type of wire, wire size, overcurrent protection, enclosures, etc and much more are covered by codes (laws). Your project sounds simple enough that a qualified electrician could manage nicely. As simple as it is there are also plenty of ways to do harm.
stevez
stevez is offline
Old 25th September 2008, 04:29 PM   #7
Using mains powered solenoids is not a good idea. Pinball solenoids would be ideal and they operate on a much safer 48V. Find a local pinball spares supplier and go see what they have. The solenoids used for the flippers are particularly good as they have a power coil and a hold coil so they can move a reasonable weight and then hold it at a reduced current. I see you are in Chicago, home to some of the most famous pinball companies in the world.
P.S. not local but a good supplier Clicky.
Pommie is offline
distribution, power, question
Distribution Transformers RODALCO General Electronics Chat 5 8th August 2007 01:16 PM
Audio Power Distribution Amplifier clipo Electronic Projects Design/Ideas/Reviews 29 26th August 2006 03:01 PM
Power Distribution Unit 0 Unit? shermaine General Electronics Chat 4 15th June 2005 07:59 AM
home video distribution kit erwin_ph General Electronics Chat 2 22nd December 2004 03:28 AM
home tv distribution bogdanfirst General Electronics Chat 15 15th September 2003 02:15 AM
